Thread: How to: JDM Power Folding Mirrors Rewire
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 55
    this is assuming you have the jdm switch AND plug with wires coming out of it...
    JDM Folding Power Mirrors:
    Use the existing plug from the OEM mirrors. (The one that connects to the door…its obvious) cut all wires there but leave enough wire to splice JDM harness.
    JDM Mirror harness OEM Plug harness
    Blue <------> White
    Yellow <------> Green
    White <------> Blue
    The other two wires out of the JDM mirror harness are for the folding function. You must run two new wires to switch.
    JDM Mirror Harness NEW WIRE JDM Switch Harness
    Green ------------ Brown
    Orange ------------ Sky Blue
    JDM Mirror Switch
    Cut the wires from the OEM switch…leave enough to work with and splice as follows, starting from the OEM wires.
    OEM Wires JDM Switch Harness
    N/A <------> Green/white
    N/A <------> Black/yellow
    Black/silver stripe <------> Black/silver stripe
    Blue/yellow <------> Orange/blue
    Green/black <------> Orange/black
    Orange/blue <------> Blue/yellow
    Orange/black <------> Green/black
    Orange/yellow <------> Red/yellow
    Blue <------> Blue/silver stripe
    Some corrections:
    Mirror Switch wiring :
    Green/white and Black/Yellow from the JDM switch are actually for Illumination. It works and lights up the switch. It uses the same color wires that are left on the oem wiring.
    Cali: Sig 3/28/2011
    Fort Worth, TX
    1,418
    what happens if you got the module also? would it not be easier to use the module.
    what do you mean by module?
    Cali: Sig 3/28/2011
    Fort Worth, TX
    1,418
    I got the switch and the module that is under the dash from the JDM car they took it off. I will take some pics when i get home.
    Since you don't have the module, I believe it give you the option to when you want your mirror to open and use what ever trigger, like when the car turns on, or when you disarm your alarm like that. So you don't have to do it manually all the time.
    i need that module, where i get it from?
    BlackGoose
    '07 Charger SXT
    Fort Worth, TX
    1,418
    I got it with the one you posted and i bought it real quick remember it just came in there.
    <div class='quotetop'>QUOTE(Dominicano)</div><div class='quotemain'>I got it with the one you posted and i bought it real quick remember it just came in there.</div>
    mine just came with the JDM switch but no harness so i bought one from TriggerMauve
    ao what doe sthe module look like/do?
    BlackGoose
    '07 Charger SXT
    you should be able to use the relay module from a toyota or hondas since those are easier to find than mitsubishis. the honda one i believe is the most common, you just have to make sure you have the wiring diagram so that you know what to hook up where.
    12-17-2002
    Sherman Oaks, California
    4,304
    i'm going to see if this is close at all to the 7G jdm folding mirrors.......
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Fort Worth, TX
    1,418
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>relay module.</div>
    Thats the name I was looking for
    so eBay has these relay modules?
    ok so eBay does have relay modules, but different kinds!
    which one to get?
    BlackGoose
    '07 Charger SXT
    hey cali. do you have a pin diagram for the switch?
    the reason i say that is that the 8g jdm mirror switch
    looks like the 7g jdm mirror switch
    and the 6g jdm mirror switch
    so if the pin layouts are the same then they might just be the same exact switch which would make wiring the 7g and 6g cars almost as easy.
    i might have pinout...i'll look for it today and get back.
    Cali: Sig 3/28/2011
    11-24-2002
    Originally TGCNY, Now TGCTX
    1,781
    what's the model number for the 8g jdm power folding mirrors?
    -Pedro
    12-17-2002
    4,304
    i checked the 8G JDM wiring against my jdm mirrors, and not one wire matches up (color wise at least), so i guess it's completely different. if you have a pinout for the 8g that'd be awesome
    1994 Galant GS 5spd
    Experienced TGC Member Bezzle's Avatar
    11-12-2005
    Paterson TGCNJ
    1,940
    i love dusting off old topics...i just figured out how to wire the 8G switch to a pair of 7G mirrors.ill draw out a wire layout diagram for it later.but heres a pic of the 8G relay module for further noob reference...
    <div class='quotetop'>QUOTE(bezzle)</div><div class='quotemain'>
    </div>
    so i need this module? or do i have it already. this topic is confusing me. Fuck my mirrors...who wants them?
    BlackGoose
    '07 Charger SXT
    <div class='quotetop'>QUOTE(GreyGoose'01)</div><div class='quotemain'><div class='quotetop'>QUOTE(bezzle)</div><div class='quotemain'>
    </div>
    so i need this module? or do i have it already. this topic is confusing me. Fuck my mirrors...who wants them? </div>
    I didn't use that module.
    03-01-2005
    Houston, Tx
    1,049
    <div class='quotetop'>QUOTE(FrankMB)</div><div class='quotemain'><div class='quotetop'>QUOTE(GreyGoose'01)</div><div class='quotemain'><div class='quotetop'>QUOTE(bezzle)</div><div class='quotemain'>
    </div>
    I didn't use that module.</div>
    me neither.... I just hooked em up and went my merry way
    Hey GreyGoose I'll take your mirrors.
Tags for this Thread
