Thread: How to: JDM Power Folding Mirrors Rewire
Page 3 of 3 FirstFirst 123
Showing results 41 to 55 of 55
  1. #41
    Quote Originally Posted by Armageddon Sunset View Post
    X10! on a translation of this, this would help me out as well. Just looking at this kinda helps me see what I have and what goes to where.
    If you get it figured out, let me know :)
  2. #42
    Quote Originally Posted by Bustedsm View Post
    Don't mean to bring up such an old thread but I bought two good condition 6th gen JDM VR4 mirrors with harness, switch (harnessed), and relay (harnessed) and was wondering if anyone could help me out with translation or how to wire these damn things up? Here are the two links I'm currently working with!
    http://www.galantvr4.org/img.php?id=38274&width=800
    http://www.galantvr4.org/img.php?id=38275&width=800
    TIA
    just to make sure do your wire colors match mine?
    JDM mirror switch
    green.....might be a faded blue
    white.....might be white-yellow stripe hard to tell
    black
    yellow-blue stripe
    yellow-red stripe
    green-white stripe
    green-red stripe
    brown-blue stripe
    brown-white stripe
    blue-yellow stripe
    black-yellow stripe
    JDM relay
    black
    brown
    brown-white strips
    brown-blue stripe
    brown-black stripe
    red-black stripe
  3. #43
    Member nyjets985's Avatar
    12-08-2008
    the 732 jersey shore, bayville
    299
    double post **
  4. #44
    12-08-2008
    299
    does anybody know how to wire these up so they will fold when you lock the doors with your remote ??
  5. #45
    05-01-2008
    Manitoba
    1,589
    Why would you like to do that? The mirrors angle is not gonna be proper.
    Tuned 2013 Evolution X GSR PB
  6. #46
    Quote Originally Posted by nyjets985 View Post
    You need the remote relay to make it work.
    Quote Originally Posted by Galante View Post
    That is only because the RHD mirror, but that is solved with cutting LHD mirrors.
  7. #47
    02-07-2007
    ORLANDO
    1,599
    ...or using mirage glass
  8. #48
    12-08-2008
    299
    so when i park my car they will fold automatically when i lock the car ... wat is the rremote relay you talk about i didnt see any type of info on that while searching
  9. #49
    can somebody do me a favor really quick.
    i lost my oem mirror harnesses i think i threw them away so i am wiring the mirrors directly into the wires in the doors, but the colors dont match up, can sombody tell me what colors on the oem harness and coresponding colors after the pulg in the door.
    i hope that makes sense.. the colors in my doors are
    blue yellow
    red yellow
    green red
    black
    orange blue
    and im supposed to have a white green and blue..? im a little confused..
  10. #50
    okay i got it figured out but im still a little confused because my jdm mirror has 2 black wires coming out of it also, that dont seem to do anything, and there is no mention of them anywhere in this thread...
    maybe they are for heating? i dont know, they are both black so maybe they are both grounds? but the mirrors still work without them plugged in so i dont know.
    what did you guys do with the 2 extra black wires coming out of the mirrors?
  11. #51
    You are correct, the 2 extra black wires are for heat, you got heated mirrors now. See if your car is prewired for them, my gtz had heated mirrors.
  12. #52
    yea there are 2 extra wires on the harness too, one is black and the other is red and green i bleieve but i cant really remember.
    does it matter which goes to which?
  13. #53
    It's been years since I did my mirrors, but I don't think it matters anyway.
  14. #54
    Fort Worth, TX
    1,418
    so i got an issue, i no longer have the pig tail that connected to the USDM mirrors. i needed to know which corresponding colors connect to what on the male connector. currently the colors on the male connector are:
    Driver: Orange/Blue, Blue/Yellow, Red/Yellow and the
    Pass: Red/Yellow, Light Green/Blue, Orange Blue
  15. #55
    Luckily, I can use the following diagram to figure out the JDM function for the wire harness.
    My issue is that I need to also find the function diagram for the USDM wires (which colors do what).
    I have a 2003 ES, did this install according to Cali's wiring and everything powers up/folds/operates, except UP is LEFT, DOWN is RIGHT, etc.
    Does anyone have the USDM diagram that tells what function the wires do? anyone else have this issue? Any help is much appreciated!
    This was for a 7G:
    Quote Originally Posted by Blue Ice View Post
    OEM colors -------------- Jdm Wires
    (dash)-------------------(harness)
    Blue/ orange stripe---- blue (12v)
    black ---- black (ground for whole system)
    yellow/ red stripe---- orange/blk strp (left and right passenger side)
    green/red strp----- green/blk strp (up down, passenger)
    yellow/ blue strp----- Blue/ yellow strp (left right, driverside)*
    green/blue strp------ orange/ blue strp (up down driverside)*
    brown/ blue strp----- red/yellow strp (switched + for both mirrors)
Tags for this Thread
