You have to port the intake manifold opening to match the TB in order for the swap to be worthwhile. Whether the 7G mani actually needs to be ported at all, someone else should know better than me, 'cos mine came with a 60mm TB. 8)
The 1G TPS is a three wire with an external closed throttle switch, the 2G and 7G use a 4pin TPS with the switch integrated, so that needs to be swapped. And, whenever (re)moving the TPS you have to calibrate it thus the need for the ohmeter.
