Thread: Tearstone V6 Turbo Kit (Lots of Pics)
Page 6 of 8 FirstFirst ... 2345678 LastLast
Showing results 101 to 120 of 157
  1. #101
    11-05-2003
    San Francisco Bay Area
    1,517
    SHE LIVES!!!!!
    Finally got her running - I haven't taken her out on a test drive yet, as I don't have the headlights or bumper cover on, but my car is idling beautifully!!
    :twisted:
    And to think, it was all because of a friggin miswire on the emanage harness :oops:
  2. #102
    sweeet we need pics and vids when you have it going.
    Back in the Family!!
  3. #103
    Sweet, I'm going to need your phone number in about 3 months, I intend to spend my anual bonus and tax refund on this upgrade
    <img>
  4. #104
    Quote Originally Posted by ChikagoGTZ
    u and me both
  5. #105
    congratss bro...i kno it must been a great feelin..any update did tear give u intrusctions yet? i been readin the v6 install on club3g seen u ask for it
    00 Galant ES Turbo/5-Speed
    13 GTR
  6. #106
    11-05-2003
    1,517
    Damn, hearing the car start and idle for the first time was orgasmic.
    I haven't received the instructions from Russ, but I was able to figure it out with the help of the other Eclipse guy that was installing his kit. Actually, there were no instructions ready yet, as the Eclipse guy and I were the first to install the kit outside of the shop. Instructions should be ready by the time anyone else orders their kit. I'd be happy to help out for any other installs.
    I'll get more vids and pics hopefully later tonight.
    My last problem right now is with the Braille battery - it doesn't seem to be holding a charge, so I'm going to check my alternator, but if the alternator checks out, I'm going to install a trunk relocation kit instead.
  7. #107
    ya...why not get an optima in the trunk??? i kno it must put more volts then tha brille
    13 GTR
  8. #108
    theblackpearl
    holy fuckin shitttttt!!!!! dude im so stoked for you and this and omg this is awesome..youre driving this beast to the meet on the 22nd and i dont wanna hear any excuses..fuck yeah!!!!
  9. #109
    Quote Originally Posted by wanderingpinoy
    yeha its a little mre work but no biggie.
    take 40 lbs off the front axle and add 40 lbs to the rear. thats 80 lbx closer to even weight distribution. just get a autozone marine battery box for now so you cna get her running, then order the nhra legal battery box and install it at your leisure.
    if you mount the battery passenger side rear, it will help to offset the weight of the driver.
    to keep things simpl i just god some heavily sheilded 4 gauge wire from home depot and ran the positive from the stock battery terminal(just used a 4 gauge electric coupler and wrapped it in tape)i ran the wire under the body as close to the frame rails as possible so the frame rail would protect it from abrasion(make sure you run it on side of the frame rail opposite the hard fuel and brake lines.)
    then i grounded it in the trunk. part of me wants to run a low resistance cable back to the front so i can ground my engine grounds directly to it.
    but when the battery is in the trunk, the fuel pump rewire is a piece of cake. jsut a couple feet of wire each way.
  10. #110
    Congrats and Welcome to the V6 Turbo club :twisted:
  11. #111
    Yah that braille looked pretty small to start your v6 dailey. I paide $60 locally for my Optima yellow top.
    I drained my yellow top once. Between starting my car w/o an alternator hooked up and leaving my lights on one night it got drained, not completely, just wouldnt start. Hooked up a battery charger, set it to the 14v start, started up first crank. Havent have a problem since.
  12. #112
    11-05-2003
    1,517
    Some quick vids:
    Starting up, view from engine bay (5MB):
    http://www.filelodge.com/files/hdd5/112259...1-08Startup.mpg
    Starting up, view from rear - Magnaflow Street series muffler on stock catback exhaust piping (5MB):
    http://www.filelodge.com/files/hdd5/112259...flowMuffler.mpg
    Test drive, slowing giving it a bit of throttle :twisted:, then trying to get home before the battery dies :oops: (10MB):
    http://www.filelodge.com/files/hdd5/112259...08TestDrive.mpg
    Videos Hosted Free at Filelodge
    Yeah, I'm thinking that the Braille is more suited to the 4 cylinder cars than our V6s. Haven't been able to find a relocation kit locally, so I've got one on order from Jegs.
  13. #113
    hehe listen to that 255 whine! Yours sounds louder then mine, probably just cause the camera is in the back seat
  14. #114
    sounds pretty good. you still have some exhaust leaks?
    you ready to drop the hammer and become one with the dark side of the force?
  15. #115
    11-05-2003
    1,517
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>hehe listen to that 255 whine! Â*Yours sounds louder then mine, probably just cause the camera is in the back seat </div>
    Yeah, that pump is friggin loud, but it also helps that I don't have my back seat in yet.
    <div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'>sounds pretty good. you still have some exhaust leaks?
    you ready to drop the hammer and become one with the dark side of the force?</div>
    Haven't really checked the exhaust for leaks, but it looks like the underhood smoke has subsided.
    Once I get the battery in, I'm going to do some more test drives, this time with my laptop logging the Zeitronix data and my PDA logging the ODBII stuff. It is soooooo tempting to drop the hammer on the throttle, but I want to make sure everything is running smooth.
  16. #116
    12-17-2002
    Sherman Oaks, California
    4,304
    damn that fuel pump is loud. can't wait for some wot videos :shock:
    http://socallifestyle.com/
    1994 Galant GS 5spd
  17. #117
    yeha just listen for popping when you are coasting. if you have leaks you'll hear them. don't forget of course to retoque all your exhaust bolts after your 1st or 2nd heat cycle. they like to come loose when they heat up. especially those tials.
    i love my 255 hp
    sounds like a harrier when i'm idling at a light
  18. #118
    how many rpms did u hit when u finished the "UOHHHHH DAMN" comment? sounded like it was gonna rip a new asshole on the road!!
    Diego
  19. #119
    its sounds mean man. Did u even really press the gas pedal cuz you sounded ass if u almost pissed yourself. Im going to order this kit next week. I just can't and dont have the time to install it myself.
  20. #120
    if you watch closely in the driving vid you will see him get pushed pack in the seat a little. just a taste of the boosted goodness.
    needs more fuzzy dice g-force meter.
