id leave it
other than that, it looks good
I posted some pics in the other forum and someone stated that i should change my brake pedal, i know that already but have no way of getting the brake pedal right now and my only other brainstorm was to cut it.
What do you guys think? I was thinking bout cutting the paddle to the shape of the clutch paddle, you can see the lightly traced lines i did in pencil on the pad.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
id leave it
i say cut it a little bit, the pedals are a tiny bit too close and every once in a while i'll clip the brake pedal with my shoe on the clutch
<div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>i say cut it a little bit, the pedals are a tiny bit too close and every once in a while i'll clip the brake pedal with my shoe on the clutch</div>
i didnt even notice that
cut it a little, but not as much as you drew with pencil
you sure cuz if i cut too little i will never get a pad on it, I figure the pencil outline i used from the clutch pedal should be right. Or you think thats over kill?
<div class='quotetop'>QUOTE(bronxbombr)</div><div class='quotemain'>you sure cuz if i cut too little i will never get a pad on it, I figure the pencil outline i used from the clutch pedal should be right. Or you think thats over kill?</div>
too small....you wont be able to find it
the first couple days would be a pain.....but after
that, it wouldnt matter much
you can always get some custom pads made
so how much exactly do you think i should cut, can you draw a line.
id say about a half inch from where your line is
it will get it out of the way enough to be useful, but wont make it too small
you can even cut at an angle, or a crazy design or something
nice, i didnt even think about it like that.
thats how i want it to be.
my suggestion. get your MT pedal pad or pedal covers, first and then use that to decide how much to cut away.
Allan has the right idea. Definitely cut it. If you dont have a pad to trace, use cardboard and trace the clutch pedal and make a cardboard cutout to use as an outline for the brake pedal
Ya the lines I traced are a trace of the clutch pedal pad itself. But gonna try to dremmel it off like you say.
Also, the cable where it tells the ECU the car is in park, what do i do with it?
I know i should cut it but where exactly can i put it so its out of the way and will cause no problems?
<div class='quotetop'>QUOTE(bronxbombr)</div><div class='quotemain'>Ya the lines I traced are a trace of the clutch pedal pad itself. But gonna try to dremmel it off like you say.
I know i should cut it but where exactly can i put it so its out of the way and will cause no problems?</div>
why not just ground the nuetral safelty switch(pin) on the ecu itself and throw that cable to the dogs?
<div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'><div class='quotetop'>QUOTE(bronxbombr)</div><div class='quotemain'>Ya the lines I traced are a trace of the clutch pedal pad itself. But gonna try to dremmel it off like you say.
why not just ground the nuetral safelty switch(pin) on the ecu itself and throw that cable to the dogs?</div>
So all we need to do is ground the cable, and that will let us start the car with no problems
1994 GS DOHC 2.4L 5spd (For Sale)
1996 S SOHC 2.4L 5spd (Up and Running)
<div class='quotetop'>QUOTE(Joaltava)</div><div class='quotemain'><div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'><div class='quotetop'>QUOTE(bronxbombr)</div><div class='quotemain'>Ya the lines I traced are a trace of the clutch pedal pad itself. But gonna try to dremmel it off like you say.
So all we need to do is ground the cable, and that will let us start the car with no problems</div>
ditto?
actually i don't know what i was thinking.
its going to be in the starter circuit.
i would just find which wire on the tranny is the nuetral saftey wire, then ground it or whatever.
wheather its on the tranny or in the shifter idk.
but somewhere there is a wire, and thats all it would take.
i zip tied mine open and buried it under the carpet. hope that zip tie doesn't come undone cause then my car isn't starting
