Thread: TearStone-8g I-4 Turbo Info 4/3 update pics/ vid/ #'s
Page 2 of 16 FirstFirst 12345612 ... LastLast
Showing results 21 to 40 of 310
    12-17-2002
    Sherman Oaks, California
    4,304
    so how does the tearstone kit know how to add fuel for the amount of boost your running?
    http://socallifestyle.com/
    1994 Galant GS 5spd
    11-05-2003
    San Francisco Bay Area
    1,517
    <div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>so how does the tearstone kit know how to add fuel for the amount of boost your running?</div>
    Wouldn't that be the job of the FMU? Not sure which FMU comes with the budget kit, though.
    12-17-2002
    4,304
    <div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'><div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>so how does the tearstone kit know how to add fuel for the amount of boost your running?</div>
    Wouldn't that be the job of the FMU? Not sure which FMU comes with the budget kit, though.</div>
    ok i see. so the tearstone kit uses a FMU to add more fuel under boost and relies on the stock FPR to keep fuel going when not under boost. with an aftermarket FPR you can do the job of both those things, and get rid of the problems a FMU will cause
    1994 Galant GS 5spd
    <div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'><div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'><div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>so how does the tearstone kit know how to add fuel for the amount of boost your running?</div>
    ok i see. so the tearstone kit uses a FMU to add more fuel under boost and relies on the stock FPR to keep fuel going when not under boost. with an aftermarket FPR you can do the job of both those things, and get rid of the problems a FMU will cause</div>
    just need larger injectors and something to tune w/ electronicly
    but like i was saying. for the money you spend on the super expensive in cabin fuel gauge w/ isolator. you could spend that on a 1:1 boost referencing fuel pressure regulator(comes w/ the gauge already). and then get a set of dsm 450's to tune with. they sell for 60-90 bucks all day long.
    you will already have emanage, so tuning the larger injectors isn't going to be much of an issue.
    "The budget intercooler is the same one we are currently using on all of our kit's"Tearstone website
    for the injectors i got this...
    thats my fuel setup..
    440cc Bosch Fuel Injectors
    Fuel Injector Clips
    Fuel Injector Spacers
    Fuel Rail Hardware
    Fuel Management Unit (FMU) 12:1
    Fuel Hose & Clamps
    MAS Modification Kit
    00 Galant ES Turbo/5-Speed
    13 GTR
    12-17-2002
    4,304
    looks good
    1994 Galant GS 5spd
    <div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>"The budget intercooler is the same one we are currently using on all of our kit's"Tearstone website
    Fuel Injector Clips
    Fuel Rail Hardware
    Fuel Hose & Clamps
    MAS Modification Kit</div>
    does the basic kit come w/ emanage?
    11-05-2003
    1,517
    <div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'>does the basic kit come w/ emanage?</div>
    The budget kit comes with the FMU, while the enhanced kit comes with the eManage.
    makes sense.
    11-05-2003
    1,517
    Off topic, but I'm actually glad I'm doing my turbo install myself - I'm actually starting to understand all this turbo talk
    <div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'>Off topic, but I'm actually glad I'm doing my turbo install myself - I'm actually starting to understand all this turbo talk Â*</div>
    yeah i wish i could get a cadaver through tearstone or ebay to play around w/ so i could get the whole "general surgeon" thing going for me.
    i figure after a few cuts and stitches i'll be ready to practice on the living.
    ya budject does not come wit emange,im getting that seprately
    13 GTR
    11-05-2003
    1,517
    <div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'><div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'>Off topic, but I'm actually glad I'm doing my turbo install myself - I'm actually starting to understand all this turbo talk Â*</div>
    ...</div>
    <div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'><div class='quotetop'>QUOTE(DOHCSTUNR)</div><div class='quotemain'><div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'>Off topic, but I'm actually glad I'm doing my turbo install myself - I'm actually starting to understand all this turbo talk Â*</div>
    ...</div>
    </div>
    nah i'm serious
    <div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>ya budject does not come wit emange,im getting that seprately</div>
    if you are getting it seperatly, then you won't need the fmu. like i was saying then, just get the afpr and ditch ithe in cabin fuel pressure gauge. sweet.
    so ditch the fuel prssure?? and instead like stated before just get oil pressure? whats a "afpr" Air fuel presurre regular?
    13 GTR
    <div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>so ditch the fuel prssure?? and instead like stated before just get oil pressure? whats a "afpr" Air fuel presurre regular?</div>
    adjustable fuel pressure regulator. as long as its 1:1 referencing.
    you don't really NEED the oil pressure gauge, so long as you know you have oil pressure. given that your motor isn't old.
    don't get me wrong. my oil pressure gauge allows me the privelage of knowing when my oil is warmed up enough to drive hard. it also gives me a little piece of mind. but i hardly ever look at it. and if it hit zero, i doubt i would notice. i would notice however, the oil pressure warning light coming on. which of course you already have.
    12-17-2002
    4,304
    at this time i would like to point to this good fpr tutorial over on galantspeed
    1994 Galant GS 5spd
  19. #39
    <div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>at this time i would like to point to this good fpr tutorial over on galantspeed</div>
    that is a great tutorial btw. and if you are looking for something simpler, there are bolt on afpr's out there to eliminate the need for the extra plumbing. if that interests you
  20. #40
    Will this be okay he ratio is what u stated..
    http://216.242.145.16/products/product.phtml?p=10
    do you think its worth getting the emange and ditching the FMU..Agian im not gona be doing anything major i just wanna install it and drive..i figure the only reason i get emange is for tuneing..im gona run under 10PSi this is my daily driver,so i dont wanna buy things which i will not use..so if the FMU will do the job im fine wit that and ditch the emange it save me few bucks but if i need it ill get it..
    13 GTR
