Thread: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
Page 10 of 20 FirstFirst ... 67891011121314 ... LastLast
Showing results 181 to 200 of 385
  1. #181
    alright awesome thats what i wasnt sure about..so a new ecu isnt necessary then? i dont know why but i felt like i read that somewhere.. but thanks for the help, im starting tomorrow i cant wait.
  2. #182
    rocky 8g
    ok a lil stuck here how do i get this pilot bearing out
  3. #183
    Bronx NYC (reppin)
    3,489
    you can either chisel, prybar, or screw driver it. Or go to autozone and rent the tool for it.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  4. #184
    rocky 8g
    ill try that iam doing it now thx
  5. #185
    rocky 8g
    wow yo this ish really works i got pilot bearing out in less than 5mins http://www.youtube.com/watch?v=1xuR7T8G1Ys
  6. #186
    05-03-2007
    Socal/Central Coast
    3,803
    Just a note: If you get an OEM replacement shift boot for the 91-99 3000gt, the base isn't wide enough for the trim ring in the 8G. I'll get pics of it when I can
  7. #187
    TGC Regular stvn_mj's Avatar
    07-30-2008
    Avondale, Arizona
    961
    ^Damn and I was gonna get one. There was a thread where its said they would fit. Also the 1g eclipse shift boot would fit but you need to remove the wire on the base.
  8. #188
    rocky 8g
    Ok I got ever thing in but when I turn the key I get this click the high speed winding sound from starter as if its not hitting the flywheel I. Try useing 2 1/8 washers one on each bolt and it still dose the same thing ..... I check my pullys to see if they are spinig when I crank the car but their not spining...then I check flywheel to see where its at and its in the right place .......fyi iam using 2g flywheel and starter
  9. #189
    rocky 8g
    is their a differents in flywheels for the 1997 fwd and awd cuz i belive they sent me a awd one cuz the teeth are not next to starter
  10. #190
    yes it has to be a FWD.
  11. #191
    how did you guys mount the top of the clutch pedal assembly? theirs clearly a spot but im just wondering how exactly did you attach it? Im assuming through bolts but im a bit nervous to go drilling into that piece.
  12. #192
    04-10-2005
    NYC
    3,695
    yep bolts
  13. #193
    01-19-2007
    Lyndhurst, NJ
    3,473
    The pedal attaches to the mater cylinder.. The master cylinder has two bolts coming into the firewall where those pre cut out holes are.. Those bolts is where the clutch pedal will attach to.
  14. #194
    11-29-2009
    Chadds Ford, PA
    2,768
    is there something on putting the clutch on correctly and running all the lines, sorry i know nothing about trans if somebody could show me a diagram of it all it would help greatly. thanks
  15. #195
    07-30-2008
    Avondale, Arizona
    961
    The diagram is on the first page look where its says research. It has pages of diagrams Goosey used for this swap.
  16. #196
    yeah i know that but is that the only thing holding it in place? theirs mounting holes on the upper part of the pedal assembly apart from the master... or is that part unnecessary?
  17. #197
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by stvn_mj View Post
    haha thanks man i didnt realize that was a link. On installing the cltuch the link was dead
  18. #198
    Quote Originally Posted by g-ride View Post
    you have two bolts on the firewall, and then 2 bolts up top underneather your dash pretty much.... but you will have to buy those 2, and the bolts that come with the master, are the same thread and pitch as the ones that go underneath the dash, 15mm long thats what i got.. fit perfect...
  19. #199
    So whats the deal with re-wiring the speed sensor on the 2002 models? Cant seem to find anything and im about to go buy a 2002 GTZ...i found where u can just pull out the tranny solenoids and plug them in to stop that CEL but I dont see anything on the speed sensor? Also, do I need a transmission mount from the manual car and which mount is it? thanks!!
    2.4 liters of whoop ass.
  20. #200
    05-03-2007
    Socal/Central Coast
    3,803
    I don't know about the speed sensor, but you need the driver side transmission/engine mount
    ie: the one that bolts to the top of the transmission
