Thread: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
Page 13 of 20 FirstFirst ... 391011121314151617 ... LastLast
Showing results 241 to 260 of 385
  1. #241
    10-18-2007
    Glen Burnie, MD
    1,314
    I'm swapped if u need a hand.
  2. #242
    ISMASG90
    You got it, thats why i want to do it for fun and performance. Im being sincere, I really dont know how to do it but I guess I'll learn something here. Im curious and hopefully this year I'll do it. :)
  3. #243
    ISMASG90
    WG, thanks man! Im gonna start saving for anything that needs to be spent on.
  4. #244
    10-18-2007
    Glen Burnie, MD
    1,314
    Yea I have a thread on here with all the parts I needed along with prices and where I got it from.
  5. #245
    05-01-2008
    Manitoba
    1,589
    What happened to the pictures from the 1st page? looks broken, is it just me or true for everyone?
    Tuned 2013 Evolution X GSR PB
  6. #246
    pics are broken. Any one know which shifter bushings fit? For the cables and the base? do i need to get for the 2g eclipse or is there a specific one for the 3g? Thanks
  7. #247
    I'll fix it...
  8. #248
    hey are you still running the act 2100? how is it holding up with the turbo? Im thinking about getting it because the last eclipse i drove had it and it felt good.
  9. #249
    Its running goood
  10. #250
    I have a question is any one running with out a pilot bearing? any problems? because the sonata flywheel center is too small for the stock pilot and i know its the same with a 2g flywheel.
    dealer only will sell the pilot bearing to me with the flywheel.
  11. #251
    Just wanted to say thank you for making this thread and my swap a little easier.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  12. #252
    hey goosey can you show us a pic of the engine bay. Also where are those earls fittings and ss clutch line going ?? im gonna start gathering parts again for my swap but i want to see what im missing in the engine bay..
  13. #253
    btw for that left bolt a swivel end ratcheting 12mm wrench works great took me 5mins to get it off.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
  14. #254
    Question.... and I hope Galante doesnt mind me stealing this picture from his build thread but what it the round spacer for the fly wheel used for?
    I was looking through pictures of my 5 speed swap and I dont remember putting that disk spacer on....
  15. #255
    05-03-2007
    Socal/Central Coast
    3,803
    I know your question is pretty old, but I don't think that specific spacer is as important. The more important one is the one that has the hole that's is about 1/2" diameter, for the clutch alignment tool. This ring just goes beneath that.
    The order of parts is->
    engine
    flywheel
    spacer with big hole
    spacer with clutch alignment hole
    bolts
    ... at least I'm pretty sure that's it. Too lazy to look through the FSM right now lol
  16. #256
    pic revival plz
  17. #257
    does my computer suck or do the pics not work anymore?? lol
    2000 G-lant ES
  18. #258
    Just fyi the 5 speed trans we have use GL4 liquid and the syncromesh is GL5. With gl5 i notice the shifter is a lot more notchy, I changed to royal purple 75 90 which is GL4 and the shifting is much smoother than with any of the other liquids. I could not find oem as they dont sell them around here anywhere.
  19. #259
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by Johnathansgalant View Post
    From evoM:
    Quote Originally Posted by Darkstar1 View Post
    The issue is the compatiblity of the fluid with "yellow metals". GL-4 fluids are OK, whereas GL-5 fluids are not. Check out this data sheet on Pennzoil Synchromesh, it states that it is compatible with "yellow metals" and thus safe to use in your EVO.
    http://www.pzlqs.com/Tech/Pdsheet/Do...omeshFluid.PDF
  20. #260
    Redline MT-90 should be safe as well. It's a GL-4 75w-90
