I'll put pix up later on today
still no pics. fix plz. planning on purchasing parts tax return
2000 G-lant ES
Fixed
thank you! i have a couple questions.. is there any wiring i have to change? and i did not know what you meant when stating to short out pin 7-8 and 9-10. i am planning on collecting parts starting with my tax return. also there is no changes needed to our stock ecu unless we want to convert to turbo correct? and i just want to gather as much info to make it that much easier.
2000 G-lant ES
hey I recognize that hand! ;)
I'm actually wearing that shirt right now haha
Lol yeah thats your pic, I found it during my research and wrote the instructions
4g64T 5spd
glad you did cause I totally mislabeled the original pic haha
Anyway, galant 108, most of the info you need is in this thread, you just have to read through it. I think I read this thread like 30 times before even considering doing the swap. And then sometimes you just gotta pop the hood and check out what's going on.
For the wiring, all you need to do is follow the instructions in the pic OMEGA PHX posted, and the ECU will be fine as long as you have a year 99-01 Galant I believe.
info and pic are greatly appreciated! can't wait to start buying parts.
2000 G-lant ES
best way to do it is dive right in and get it done, i actually did mine without the tutorial, its pretty straight forward, the physical is just as much work as basically changing a clutch to me, and the wiring took only 5 minutes
I came to lurk just to see if this forum still existed. Imagine my surprise to see this:
I recognize that custom Xenarc dash piece anywhere from my first carputer build which I sold separately on eBay after I pulled it from my 2002 Galant.
Talk about a flash back. Happy to see that its still alive and kickin'
where did you get the 50/50 tails and the E-brake assembly from?
50/50?
I believe he is referring to your JDM tails.
Exactly what's 50/50
- Roman
Roman, 50/50 tails are those that have half red, half clear color. It's usually not an exact ratio, but you get the idea:
and ours
-Greg
quick question on the 5spd swap, when using an OEM 3G flywheel we use our oem starter and starter plate and there are no washers or anything that we have to use to space things out right?
