Thread: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
Page 17 of 20 FirstFirst ... 71314151617181920 LastLast
Showing results 321 to 340 of 385
  1. #321
    Bronx NYC (reppin)
    3,489
    Noobs smh......
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  2. #322
    U also need the master cylinder and tranny mount and flywheel not the flex plate. U don't need the starter plate from a 3g. And don't use a used clutch and throw out bearing.
    Got it...clutch master cylinder is what I meant when I said slave cylinder....wasnt sure about the tranny mount. the starter plate is the same from 3 g eclipse auto and stick...good to know.
    How about the check engine light?
    anyone solve that yet?
    Sign here so we can do stuff to your stuff...
  3. #323
    cel was solved, contact a member named Isaurio for the patch
  4. #324
    Tried to contact him over a month ago with no response, anyone have a link to a thread with the cel info on it? I would really appreciate it.
  5. #325
    Anyone know the color of the wires that needed to be shorted for the park/neutral switch? I chopped off all the AT plugs will doing my turbo install.
  6. #326
    Quote Originally Posted by greddy View Post
    Looks like a thick black wire with yellow stripe and thick black wire (possibly red stripe).
    This is the picture from the first post:
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  7. #327
    Thats what im guessing too if anyone knows for sure thatd be rad
  8. #328
    Confirming pins 9+10 are to be connected together.
    Pin 9 is black/red
    Pin 10 is black/yellow
  9. #329
    Awesome time to go digging into the harness thanks guys!!!!
  10. #330
    How many, if any, differences are there going to be when performing the swap on an '01 V6? It looks pretty straight-forward, and I can't see it being much different, but I should ask before I dive into it, because I really don't want to have a lot of downtime on the only running car in the household.
    Edit: Woops, I'm a n00b!
    Didn't realize there was a thread just for the V6...
  11. #331
    Re: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
    Lol at face palm yourself, but you searched and found it. Points for that.
    Sent from Tapatalk 2 using my Rooted DROID BIONIC on Android ICS
  12. #332
    OK so u know how there is extra wires from the a/t can the be removed?besides the two u need to start the car.also if removed can it mess anything up?
    STAY READY AND YOU WONT HAVE TO GET READY!!
  13. #333
    so im just about done with the swap and im here trying to get the car started. All my wiring on the harness should be correct. But no luck, wont start. So upon further review I seem to have pulled out the cable in the shifter assembly with the cone shaped pin telling the car its in park. I still have it but I cant find where it connects to, anyone have a pic of the other end?
  14. #334
    does it try to start?
  15. #335
    Quote Originally Posted by galant1983 View Post
    Nope, the starter doesn't even kick in
  16. #336
    The cables do nothing as far as preventing the car from starting once manual-swapped since they only control the mechanical functions of the A/T shifter assembly and ignition cylinder. The only thing I can think of is pins 9 and 10 on the solenoid harness since nothing else related is altered during the swap.
  17. #337
    Quote Originally Posted by Rodriguez View Post
    Pics of what u r referring to
    Sent from my Xoom
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  18. #338
    In the tutorial it says something about this thing being pushed in and bent shut and taped, being that I removed it i thought it might be a problem. Anyway i know for sure i crossed pins 9+10 on the black harness, unless its different for 2003.
  19. #339
    07-02-2011
    South Florida, by the beach
    1,076
    Here is the other end, connected to my brake pedal
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  20. #340
    Quote Originally Posted by Black8GV6 View Post
    Ok thanks, that doesn't look like anything to important. Does it have any wires going to it?
