Thread: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
Page 18 of 20 FirstFirst ... 814151617181920 LastLast
Showing results 341 to 360 of 385
  1. #341
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    I believe that's just used so you don't shift out of gear until you press the brake pedal.
  2. #342
    Quote Originally Posted by Guzm4n View Post
    Yea i figured, so what could it be? I know I've crossed the right pins.
  3. #343
    02-02-2011
    Des Moines, IA
    736
    How long has the battery been disconnected? I know I took too long on my swap & my car wouldn't start cause I needed a new battery.
  4. #344
    2 months maybe, i tried jumping it while i started the car
  5. #345
    Congrats bro
    -Danny
    Quote Originally Posted by deeznutz View Post
    Ally and her whip a day helps keep the drama away!
  6. #346
    03-12-2012
    Manvel Texas
    1,171
    Quote Originally Posted by Rodriguez View Post
    Did you figure out your problem? Just got my swap done with no issues and cruise control works like factory. Pm me if you need any help with it.
  7. #347
    Re: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
    Quote Originally Posted by coconut View Post
    So its done, she lives. Rear disk swap and The 5 speed. Shifts flawlessly. If theres anything wrong, its me learning to drive stick. Anyway all thats left is the brakes to be bled and she'll be golden. Big thanks to whokilledhoughes and johnathansgalant for their help with the swap.
    http://youtu.be/OUtVXmrv4sM
    He posted this!!
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  8. #348
    Yea guys sorry i didn't keep up with the thread, all is well for now lol. The car is another animal, and its not even boosted yet. Still waiting on a few parts for the turbo.
  9. #349
    quick question, i see that i can use a 2g clutch kit when you use the 3g trans. but will i still use the 2g clutch kitt when i use the evo trans when i do the awd swap??? also what flywheel will i use?
  10. #350
    No u use an evo clutch and flywheel I believe. Someone correct me if I'm wrong.
    '95 Kawasaki ZX9R
  11. #351
    no your right lol
  12. #352
    So if I am using the 2g starter will there be any problems not having the heat shield in place?
    When you say throw out the two flywheel spacers you mean the shims correct? Any help would be great.
  13. #353
    03-12-2012
    Manvel Texas
    1,171
    Quote Originally Posted by lazy t View Post
    I didnt use them on my swap and havent had a problem yet.
  14. #354
    Can you use the 2g release bearing. It seems to fit good?
  15. #355
    So I have completed the swap. While it is running the crank shaft is making a noise. Is it possible that the flywheel is not centered causing the main shaft to be off balance? Every thing sounds good except the harmonic balancer area. I ran it with the belts off to eliminate if I damaged a pulley during install. That was not the issue. I saw there was a line up hole on the block I eyeballed it when installing the flywheel.. Don't know if that could be my problem.
  16. #356
    I am also hearing a roaring or rattle noise in the trans. I inspected thru the bottom plate nothing appears to be damaged? I am about to go crazy!
  17. #357
    Thank you for this thread. I installed my 5 speed 2 days ago and lovin it.
  18. #358
    You welcome
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
  19. #359
    Bronx NYC (reppin)
    3,489
    did you use a OEM throw bearing, did you install the clip correctly?
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  20. #360
