Thread: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
Page 6 of 20 FirstFirst ... 234567891016 ... LastLast
Showing results 101 to 120 of 385
  1. #101
    is what? the swap?
    no fatal, the russian. lol jk.
    Jigz-TGCIL Sosick Motorsports
  2. #102
    about the same +/- 30min or so
  3. #103
    04-10-2005
    NYC
    3,695
    lol well i cant say about the russian. more or less the same you will need the pass side axle from a manual eclipse as well though.
    roman will take good care of you though. when you plan on doing the swap?
  4. #104
    I have a ? i want to do a 5speed swap to my 97 diamante....the 3.5L motor bolts str8 into an eclipse so i was wondering if the eclipse gt 5 speed tranny mount will bolt right up to the diamante i know for a fact that the tranny does bolt up to the motor.
  5. #105
    Quote Originally Posted by b1gkishan View Post
    good news, diamante automatic engine mounts are the same as the manual, so no need to use any of the eclipse mounts. Pedals are different, shifter assembly is different on the diamante, but you may be able to bolt the eclipse one in place. Good luck!!
    '00 Patriot Red GTZ --> JDM'ed... 5 Speed... ...
  6. #106
    well someone over seas has done the swap to their diamante but i guess ill be the first one in america to do so pretty soon. Slave cylinder, master cylinder, tranny, shifter, shifter linkage, clutch....and is the flywheel the same for the 72 and 74?
  7. #107
    You can use 3G eclipse V6 parts, all the parts will fit your 6G74, including flywheel, clutch, shifter linkage, but you will need to get the pedals for a LHD diamante/magna. The shifter assembly is different also, but I think it could be installed in your car. I will post some screen shots of all the parts so you can see the differences. Also, you can check AussieMagna.com
    EDIT: Screen shots link: HERE
  8. #108
    thanks for the help man! It wont let me sign up for the aussie forums cause of the type of email i need. So shifter and s/linkage may work might need some drilling if anything?? clutch pedal assembly and a brake pedal has to be from over seas?
  9. #109
    04-10-2005
    NYC
    3,695
    the tranny will definately work. there are guys running 74 swaps with the 3g transmission
  10. #110
    Alright so i can get my hands on a clutch assembly from aussie magna (it shouldnt matter even if they a right hand?)......what type of wiring would i need to do to take this auto out and put the 5spd in? what about the speed sensor and all?
  11. #111
    01-19-2007
    Lyndhurst, NJ
    3,473
    I'm just starting to source all of the parts.. Hopefully by the summer I will have everything. Yeah Romans a good dude.. Haven't seen him in a while though.. Not since the last time I saw you.. We had a meet today too.. Called him later in the afternoon and he was still sleeping.. lol
    Oh yeah.. There's a dash in my room with your name on it.. haha
  12. #112
    thestig
    i have a couple questions: one where did you get the e-brake handle/boot. also when you put the pedals in you had to change the brake pedal too? in order to make the clutch pedal fit? did those pedals come of of a 3g eclipse as well?
  13. #113
    rocky 8g
    oh
  14. #114
    2000 eclipse 2.4 5 speed at my local junk yard.
    Let me know if anyone is interested i can pull everything involved with the tranny and ship it.
    My on changing thermostat
    2001 Galant ES
    1972 Datsun 510
    1994 Kawasaki zx9r
  15. #115
    Bronx NYC (reppin)
    3,489
    where you located bro?
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  16. #116
    hey goosey... I have a question regarding the flywheel -- if u use a 3g flywheel u need the starter spaced bla bla but If i use a 3g stock flywheel can i use my original starter?? And if the stock flywheel is used will the 2g clutch bolt up or do i need to get something for the 3g?? Im gonna try to finish gathering parts for the swap soon.
  17. #117
    04-10-2005
    NYC
    3,695
    if you use the 3g stuff you need both the clutch and flywheel from a 3g. your stock starter will work.
    if you use a 2g flywheel you need a 2g clutch along with the starter
    the benefit of using the 2g stuff when he did his swap was it was cheaper overall for the upgraded components and there was more variety available. plus swapping out a new starter isnt a bad idea when everything is out of the car...
  18. #118
    thats why i ask as a matter of fact is because i just bought a starter with lifetime warranty so i want to keep it haha.. Alright thanks for the info
  19. #119
    10-18-2007
    Glen Burnie, MD
    1,314
    Getting ready to do this, in the next month or so. Im using all parts from the 3g, will I be able to reuse the stock flexplate/flywheel bolts or will I have to get new ones? Also I heard that I need 2 spacers for the flywheel? Im a little confused lol
  20. #120
    05-24-2005
    Greensboro, NC
    494
    You have to buy bolts for a manual car because the bolts on your car now are shorter.
