Thread: 8G Auto to Manual Conversion DONE! **UPDATED 02/03/06**
Page 8 of 20 FirstFirst ... 45678910111218 ... LastLast
Showing results 141 to 160 of 385
  1. #141
    if it came with flywheel bolts, then I would use them. You wont need the 2G bolts if the lightened flywheel came with bolts.
    thats awesome!! thanks man
  2. #142
    rocky 8g
    Ok dose that 2g starter half to be mt or can it be at
  3. #143
    It shouldn't matter but I would use one from a manual to be safe.
    Jigz-TGCIL Sosick Motorsports
  4. #144
    does anybody know what the transmission code is? i'm looking for a rebuild kit, ups broke the mount closest to the fire wall on the bell housing, and since i have to take the whole thing apart and replace that, i might as well rebuild the dang thing, i just can't find a rebuld kit for it lol...
  5. #145
    TGC Regular stvn_mj's Avatar
    07-30-2008
    Avondale, Arizona
    961
    F5M42 is the 4 cylinder F5M41 is the 6 cylinder tranny.
  6. #146
    thanks man edit... thats for the manaul correct? lol
  7. #147
    07-30-2008
    Avondale, Arizona
    961
    Yes sir.
  8. #148
    awesome... gotta quick question, for those of you that have install a lsd, how much was just the install price? i'm trying to get some idea on how much it would be to replace the bell housing....
  9. #149
    04-10-2005
    NYC
    3,695
    i was charges 200 for the lsd install and rebuild. including the gears... i know the guy though so you may be looking at a little more but roughly somehwere in the 2 -3oo ballpark
  10. #150
    really? wow why am i being priced like 600 for just parts alone then.... hmmm i'll have to check around... thank fatal1
  11. #151
    Quote Originally Posted by stvn_mj View Post
    correction the V6 is F5M51
  12. #152
    01-19-2007
    Lyndhurst, NJ
    3,473
    Yeah, the V6 is F5M51..
  13. #153
    07-30-2008
    Avondale, Arizona
    961
    My bad screwed up the numbers. I was reading up the fsm earlier before he asked.
  14. #154
    bout to start the swap this coming monday but i got a couple of last minute questions if anybodys knows...the rebuilt tranny i bought came with no hardware..will the automatic hardware work or am i gonna be makin another trip to the dealer..and also do i need to buy both tranny mounts? or can i use any parts from the automatic?
  15. #155
    OK I'll break it down since I had this issue.
    The hardware for the shifter cable bracket on the trans is the same as the ones on the auto, The bellhousing bolts are also the same as well as the bolts that hold the roller mount brackets to the trans.
  16. #156
    10-18-2007
    Glen Burnie, MD
    1,314
    Man that is very obvious stuff, there are numerous threads about this, as well as THIS THREAD, that contain all that info.
  17. #157
    thanks alot man i appreciate it, and white galant thanks for that buddy...
  18. #158
    04-10-2005
    NYC
    3,695
    g-ride..you will need the manual tranny mount it is different then the auto
  19. #159
    Fatal1 do you mean this tranny mount adapter? MD771071, its the one closest to the firewall...
  20. #160
    07-30-2008
    Avondale, Arizona
    961
    Quote Originally Posted by galantman03 View Post
    He means the mount that attaches to the tranny itself.
