Thread: Dimming Lights
Showing results 21 to 40 of 53
    NEWBIE
    12-17-2005
    WVC, UT (Unfortunately)
    43
    ok well i guess ive just been trying to not have to deal with the alternator again, cuz that was a pain, but if I have to do it i guess ill just do it. One thing im worried about is that it might just pass the test at autozone, or whatever but it might still be a problem does anyone know of a performace alternator I know that stinger makes some, but I dont know if they are for our cars I went to go check it out, but they didnt seem to know what they were talking about at RCWilley wich it said on the stinger website was an authorized dealer I did see that on ebay they had one for a civic (not saying that I was gonna buy one for a civic) but it was a 200 amp alternator so im hoping they make one for a galant or u know eclipse. Is there any more info on a better alternator for out car?
    My son was born!!! 4/18/06
    Easton
    Vya
    Ornelas
    NEWBIE
    12-17-2005
    43
    ok so I was looking arround and I found this http://verizonsupersite.com/4alterstartcom...nt&catuid=10013 will it fit since it works for the 1g I figured it would just from the 4G63t swap sticky, but I want to make sure or are there other Hi Output Alternators that any one would recomend?
    Easton
    Vya
    Ornelas
    New Member
    08-17-2002
    North Haven, CT
    50
    I know that in my 96 G, I have belt slip issues and mine does the same thing. Extreme pressure on the alternator can do that. Maybe you should check that out...?
    T w o T h o u s a n d O n e M a x i m a
    N i n e t y S i x G a l a n t L S - RIP
    http://members.cardomain.com/siriusgrrl
    NEWBIE
    12-17-2005
    43
    Alright guys I think I FINNALY found the issue I have been installing my new gauges (voltmeter, oil pressure, and air/fuel) and while I was trying to get my allen head bolt out from the oil filter housing I noticed that THE GROUND WIRE FOR MY ALTERNATOR WAS NOT CONNECTED!!! The bolt most likely fell out when I was driving some time after I installed it. So what do u think of that?
    Easton
    Vya
    Ornelas
    Bronx NYC (reppin)
    3,489
    I think your crazy, man just replace the bolt and tighten real good so it doesnt come off again.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    NEWBIE
    12-17-2005
    43
    Yep did that replaced it and IM STILL GETTING DIMMING LIGHTS. Jees this is makin me crazy my voltmeter is tellin me im idiling at about 10volts then ill let go of the break and it goes to 12 volts then i push the break again and it stays at about 12 then I drive and its up to 14ish. And when I first start it its up to 14 in park, and a few stops after that, but I dont know whats going on. Im gonna try getting new battery terminals in case its losing power cuz the ones I have suck, and Ill take the alternator to get it checked real soon also.
    Easton
    Vya
    Ornelas
    Bronx NYC (reppin)
    3,489
    If it is the ALt, Buy one from me and support the 5spd fund.
    NEWBIE
    12-17-2005
    43
    ahhhh great now i gotta support some sort of fund.. naw just kidden actually im gonna get a hi-output alternator so unless u have one that will fit sorry. Im also gonna swap to 5 spd, and do a 4G63t/4G64 hybrid so...
    Easton
    Vya
    Ornelas
    Bronx NYC (reppin)
    3,489
    Well if you gonna do the 5spd, I know seth has a complete 5spd swap for sale at a great price. Should hit him up.
    12-27-2005
    Charleston SC
    1,520
    Damn dude.. You and I are having the same exact problem.. I guess ill check that ground wire.. Thanks
    NEWBIE
    12-17-2005
    43
    Well im hopin I wont continue having the problem for 2 much longer Im expecting it to go away no matter what with the engine rebuild. Im gettin real tired of it, but what can ya do... I cant wait till I can get that done my gf and I work together so we can carpool in her 96' civito (which has a long lasing engine, but everything else has even better fallapart-ability) meh whatever. The gauge installs went good then I found out I have a loose wire in my turn signal so everytime I signal all my lights flash even more now like completely turn off so I tried soldering the power wire back on, but the solder just broke so Ill be resoldering again later. Im still Idoling at way to low a voltage so I'll be gettin a new battery, batt terminals, and a Hi-Output alternator that oughtta take care of it. Ill also be cleaning out and resealing the IAC soon so hope that helps. I'll keep posted on everything till I get it fixed hopefully it will help someone else out like shadow.
    Easton
    Vya
    Ornelas
    12-27-2005
    Charleston SC
    1,520
    Yea man as soon as you find out the compete problem please keep us updated cause i am having the same proble minus the blinker. And i honestly dont know if it can hold a system because i plan to put a 3000 watt power acoustic amp with 2 12's power acoustic FUBAR subs, Alll audiobahn highs and Audiobahn amp 600 watts. And i seriously dont even think the car can hold the 600 watt amp with the lights and shit the way it is.
    NEWBIE
    12-17-2005
    43
    Lemme tell you something I have a 2000 watt amp pushin a 12" 2000watt Orion H2 Sub, and NO CAP, and when I turn up the volume yeah the lights dimm a little with the bass, but guess what when I turn it off guess what happens. NOTHING same ammount of dimm minus the bass, but still the dimming lights seems to be only coming from stock shit nothing ive added. I dont know if it makes sence, but maybe I should just post vids of me driving arround with and without the amp the only accessories that seem to make a difference with the dimming is just the stuff that came with my car nothing Ive added. Example My car is dying while im at a stop light so I turn off the amp, and my fog lights what happens NOTHING my car continues dying then what I turn off my umm windshield wipers, and my heater then I start getting volts and rpms back. So I figure I can run my amp as long as I want, and if my car starts dying Ill just turn off my windshield wipers and I'm good...
    Easton
    Vya
    Ornelas
    12-27-2005
    Charleston SC
    1,520
    Hahaha i wish it was that easy for me.... my car dies like a mother fucker doesnt idle when its cold but it gets a little better when hot, cuts off at stop lights, misfires like a mother fucker, all kinds of shit.... Ive replaced the headgasket, Fuel pressure regulator, Map sensor, Checked all the other fuckin sensors, all kinds of shit but now.. it still does the fuckin same.... I dont know what the hell it is but the good thing is that my check engine light is on so now i can go to autozone and umm get their little tool to tell me whats wrong with it. The lights and shit still do dim. If either one of us figure it out then POST PLEASE. Maybe just maybe (this thought just hit me) the damn pulley on the alternator needs to be a different size... hmmmm. i dont know im no mechanic... But ill post if i figure something out.
    NEWBIE
    12-17-2005
    43
    Ok I found out where the problem is....well what systems are causing the problems not exactly what devices. Alright there is definately a problems somewhere in the throttle or IAC cuz Im gettin low Idle, but I think thats only part of my issue. The other problem is in the charging system, and I guess the lights them selves. How I found this out my gf and I went to go get some food last night, and I was watchin my voltmeter the whole time as I kept driving I found out that the charging system isnt working correctly because I was first idling at 14v then it gradualy went down to 10v so I would rev the engine and get it up to 14v again, but after driving for a while I couldnt even get it to go up to 13.5v the most was 13v even in park and reving the engine up to 2000rpms which I think our alternator tops out at about 1000rpm-1500rpms cuz thats where i noticed it wouldt make any more power. Also while I was waiting at the wendies drive thru I turned off my headlights, and all my other gauges, and my idle went up to 13v just with that so I have to figure out if its my stock shit, or if its my new gauges that is causeing the issue in the electrical. Im thinking its gonna be the battery cuz the alternator seems to be doing its job, but the battery seems like its not being charged also I think this cuz now when I open my doors the interior lights are wwwwwaaaaaayyyyyy more dim than they used to be or even than they are if I just start my car for a second then turn it off. So im thinkin I realy need to replace the terminals, and I think im gonna get a dyna-batt. From Overboost.com what do you guys think.
    Easton
    Vya
    Ornelas
    Member
    08-18-2002
    Pocono Mts. PA
    254
    Hi:
    for future reference.
    By the way, on 95's there is a TSB dealing with this type of problem, the voltage regulator on a number of alternators was bad. In addition, the switch for the rear windshield heater did not have a control to shut it down when certain time have passed. So this problem could (it did to me) drain the battery in city driving.
    Im happy it was only that nut on the ground screw.
    NEWBIE
    12-17-2005
    43
    hnmm good to know ill look into it (not being a smart ass) I truely will.
    Easton
    Vya
    Ornelas
    NEWBIE
    12-17-2005
    43
    OK I feel like a dumbass.... I checked into my rear defrost It wasnt off i havent had it off for about 3 months turned that off and my volts shot up....crazy, but I dont think it will last I still need to check into fixing my wiring cuz I think it will fix it for a few months, but it will go back down again.
    Easton
    Vya
    Ornelas
  19. #39
    Member
    08-18-2002
    Pocono Mts. PA
    254
    This car is a BIG learning curve. It never stops anoying you.
    You can get a list of TSB from (autotozone, and the ALLDATA, and a few other places) the web. you can also go to mitsu cars and pay to get in for a day and you can even see some of the TSB's fixups.
    Right now I only have problems with the SRS, see my post.
    Good luck. (If you do not need the defroster in the rear, just pull the fuse)
    The alternator - if is original then check it out, but must be done only after you pull it from the car, the regular freeby tests around and even the one on sears do not show all the problems. I had problems with mine and pull it out and took it to an alternator place and they found the problem with the regulator.
  20. #40
    NEWBIE
    12-17-2005
    43
    Well it didnt work I havent been driving my car for the last few days, and I dont think I will be driving it again for the next couple months. Im just gonna do the engine hybrid, and the tranny swap. Hope that works. By the way I was going to tell you guys the whole story of what happend to me, but i figgured I would save you guys the brain cramp. Thanks for the help guys Ill notify you if I have more issues even with the rebuilt engine im thinkin my cars just getting to the end of its life 177,000 miles. I also think the timings off so...
    Easton
    Vya
    Ornelas
