if you want a battery for a sound system, get an optima. but yea, check out the manufactuer's website all the important information is there on the homepage.
does anyone know the cold cranking amps (CCA) of the braile batteries for out cars. i want one but i want to make sure that it is powerful enough to run a sound system
The Braille battery would not be ideal for a vehicle with an extensive audio system, or areas with severe cold weather - you would be better off relocating your battery to the trunk if you need space in the engine bay.
ya i found the site this morning the cold cranking amps are near what the stock battery are and that battery barely runs my sound system. after extensive bass i can hear my engine revs to compensate for the power loss.
get an optima yellow top/light grey or a blue top/light grey for audio applications (light grey body is deep cycle).
http://www.optimabatteries.com/publish/opt...onfig/home.html
yellow top:
http://www.optimabatteries.com/publish/opt.../D34_082104.pdf
blur top:
http://www.optimabatteries.com/publish/opt...D34M_082104.pdf
get the yellow top i love mine and i got 2 12' subs amp power inverter car computer 7' monitor and mines starts up with no problem
