have you opened up the hood? checked your electrical connections? checked the fuses?
This morning I was headed to school when my radar detecter started going crazy. That's usual for that area so I just ignored it, then it started turning on and off spastically so I just unplugged it. Immediately my radio started doing the same thing, so I turned it off. My engine started idling funny so I turned around to go home. I plopped it in Neutral at all the stops and feathered the gas to prevent any stalls that might occur. I noticed that my transmission was being "chunky" when it changed gears (chunky meaning having a hard time changing gears). My windshield wipers were going so slow, they acted like they were covered in ice.
I pulled into my driveway and made sure to find a nice parking spot where I wouldn't have to move my car for a day or two. Just as I suspected, it won't start. When I turn the key, it makes that Popping noise from the starter like it doesn't have enough battery juice. I just got a new battery a month ago and did not leave my lights on the previous night.
What do you guys think happened to my car? I'm pretty sure I know, but I want to see what you have to say before I put any ideas in your heads.
99 Black GTZ
Suspension: KYB GR-2 shocks/struts, H&R Springs
Wheels: 18x7.5 ADR GT-Sports, 225/40/18 Nitto Neo-Gen
I haven't checked anything yet, it's really freakin cold and rainy out there. I'll be checking to make sure my battery still has a good connection and pulling all the fuses around noon (might be warmer then). But I have a feeling I won't find anything.
99 Black GTZ
Ok, I checked all my connections and fuses. Nothing was loose and the fuses were fine. Any suggestions?
99 Black GTZ
can you listen to the radio when the car is in acc mode?
Yes I can.
99 Black GTZ
have you tried jump starting the car?
Double check your flux capacitor as well, this is a very common problem.
<img>
sounds like your alternator is about to take a crap
[email protected] <- '01 ES V6 (detuned for daily commutes)
Black '94 Audi S4 soon RS2'd running 28 psi
Chipset [X]|Injectors[X]|Turbo[X]|RS2 Manifold[X]|Bosch 3-BAR MAP[X]
Yep. I'm thinkin my alternator died. Hence the battery not staying charged, my accessories not working when the car was running, and now the starting problem. It even coincides with the funky idling. The only problem is that I don't have anything to test it with which is why I was posting the symptoms hoping somebody else came to the same conclusion.
If it might be something else, let me know before I end up buying a new alternator by the end of the day.
Thanks for your help so far.
99 Black GTZ
take the alternator out and bring it to autozone. they,ll gladly check it out and see if it charges correctlyOriginally Posted by SROL
damn.. if it is the alternator , your lucky.
Donovan J.
Need something from england..or other eastern nations holla...
I dont mind looking.
Car: Toyota Soarer GT-T Jspec "Limited"
Galant: at home chillaxen :(
here check this and make sure it is fluxing
"If Wal-Mart is lowering prices everyday, how come nothing is free yet"
heh wtf
Donovan J.
that is a picture of a flux capacitor, what don't you have one in your car, cause mine is in the trunk.Originally Posted by ChikagoGTZ
yeah thats for damn sure man, just hope thats alll that it is. good luck with that.Originally Posted by Donovan
Yeah, it's fluxing. I just replaced it the other day. My old one was getting a little worn out. I got a carbon fiber one to replace it with so now it looks better and goes faster.Originally Posted by little blue
Good idea. I didn't know Autozone could check that. Thanks a lot guys.Originally Posted by FRCFD6
So, what else could it be? Something seriously wrong with the electrical system that would require me to rip everything out and start over again?Originally Posted by theblackpearl
99 Black GTZ
havent heard of any "whole electrical' systems going up..but alot of fuses definetlyOriginally Posted by theblackpearl
Donovan J.
Your Altenator is taking a shit on you.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
its not fuse related....sounds like an alternator or a bad ground somewhere...
