TRy one last thing. Have someone in the car turn the key to start while you are under the hood taping the starter. If that dont work you could alway get a starter from autozone, try it and bring it back if thats not the problem.
Changing the starter is cake, dont let a mechanic tell you he gotta raise the car on a lift and get it from underneath cuz its bullshit.
Remove you stock air box and intake, look there underneath the intake manifold and Bam! there it is. Get a 14 spanner or 14mm socket and rachet the two bolts holding it in there. then take the what i believe is a 12 and unbolt the wires and reconnect the new starter in reverse. And now you have learned an easy and quick 20 minute way of saving money and removing your starter.
