Thread: E brake
Showing results 1 to 6 of 6
    E brake
    Is it just me or does it feel like you have to pull the ebrake up through the roof for it to engauge? on my old galant it would engauge after like 3 clicks, on my maxima its 2 clicks? any tips on a fix?
    04 GTS 9G
    FoR Sale:
    2004-2006 Fog Lights $50
    shoot me a pm
    02-28-2005
    Metropolis
    3,540
    You'll probably need to adjust the brake cable. I don't know how to do it but its come where in the manual.
    08-23-2004
    Chaska, Minnesota
    1,370
    tighten the screw holding the line
    weres the cable?
    04 GTS 9G
    FoR Sale:
    shoot me a pm
    do you have drums in the rear or rotors? for drums you will have to take the drum off and inside to the top there is cigar shaped piece with a gear attached to it. you will have to rotate this down towards the ground to get the e brake tighten. be careful not to turn it too many times or the drum will not fit back on. I believe this is the same for rotors. anyone else now for rotors?
    "If Wal-Mart is lowering prices everyday, how come nothing is free yet"
    if you're still under warranty, take it to the dealer. if not, like the others said, adjust the cable.
