Thread: Rims question
Showing results 1 to 2 of 2
    RyzNatch
    Rims question
    What is the biggest size of wheel/tire that can be fit with the stock suspension? im thinkin about getting some 17x7.5s with low pro tires. how would this setup work on stock suspension?
    San Antonio, Tex-Mex
    1,413
    17's with say 215/40R17 tires is almost exactly equal to the stock rims and tires you have now. You can go 18 with the stock setup too no problems. When you lower your G is when you need to start considering size and offset.
    Basically you can go as big as you deem possible. 20's could fit hypothetically, but you'd need a nice fender roll for that, but that would just look dumb IMO LOL
    <-Check it out Maz
    My 7g
