Thread: 5spd Shifter Upgrades.
Showing results 1 to 20 of 31
    These all should be MUST buy mods for any 7g 5spd owner.
    First:
    Energy shifter plate bushings. Cheap mod that replaces your SLOPPY SOFT stock bushings which makes shifts more precise. Comparison, old on left, new on right:
    http://cgi.ebay.com/ebaymotors/ENERGY-SHIF...sspagenameZWDVW
    Second:
    Skateboard bearings to replace the crappy rubber bearings on the shifter cables at the trans. Simply take two skateboard or roller blade bearings and use a c-clamp to press them into the cable ends. Results are for smoother shifts, and easier to get into each gear.
    http://cgi.ebay.com/ebaymotors/DSM-Shifter...sspagenameZWDVW
    (If you dont have an old skateboard or pair of rollerblades)
    Third:
    Replica B&M Short shifter. Its adjustable between 2 different throws. At the shortest setting going through the gears is so quick and smooth when combined with the skateboard bearing mod and Energey shifter plate bushings.
    http://cgi.ebay.com/ebaymotors/T-6-Short-S...023999183QQrdZ1
    12-17-2002
    Sherman Oaks, California
    4,304
    great write-up, i did all these mods and the difference was unbelievable.
    http://socallifestyle.com/
    1994 Galant GS 5spd
    Is there anything like this for the 8G
    Not for the 8g exactly, can use 3g/Evo parts though. Energy makes a kit for the Evo/3g, theres short shifters for both, and you can get the brass bearings for under the hood as well.
    Happy shifting!
    11-05-2003
    San Francisco Bay Area
    1,517
    Just a suggestion - make copies or screencaps of the eBay auction items, as those will be removed after a couple of months.
    Good stuff though!
    <div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'>Is there anything like this for the 8G</div>
    yes. the energy baseplate bushings will fit 8g/evo/3g shifters.
    there is also a 8g/evo/3g solid brass shift cable bushihng available. will do the same thing as the ball bearings.
    here is a set
    http://cgi.ebay.com/ebaymotors/UH-SHIFTER-...1QQcmdZViewItem
    very very worth it.
    and the plate bushings
    http://cgi.ebay.com/ebaymotors/Race-8p-Pol...1QQcmdZViewItem
    also very very worth it.
    Cool, I just ordered them. Hopefully they will arrive before my scheduled install.
    Wow, I helped Galant14b do this years ago.
    Man, those were the days. :cry:
    First one: Red 88 - 245whp/312wtq - HIN: Nightshift - Chicago '07 WINNER
    Second one: Durban 88 - Buckskin - SHP - Auto - Sold to more capable hands
    Next one: White 84 flatty - t3/t4 - VELNAS - More to come
    "...Remember: Don't crush 'em, restore 'em!"
    Re: 5spd Shifter Upgrades.
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>
    Skateboard bearings to replace the crappy rubber bearings on the shifter cables at the trans. Â*Simply take two skateboard or roller blade bearings and use a c-clamp to press them into the cable ends. Â*Results are for smoother shifts, and easier to get into each gear.
    </div>
    Any chance you took down the dimensions of the bearings before you put them in?
    Mikey
    Nah but you can use any Skateboard or rollerblade bearings, both are the same. Just will need to be pressed in with a clamp or shaved a bit so they fit perfect.
    [QUOTE=seth98esT;154406]
    what vehicle should these come off of. I can only seem to find them for the evo 8
    I spoke to soon. found it here.
    https://www.dsmparts.com/customer/home.php?cat=19
    it says it will fit 91-99 eclipse, and 91-92 galant vr-4. dosen't the 7g run the same shifter as the 2g eclipse?
    12-17-2002
    4,304
    Quote Originally Posted by kaufmanp92eb View Post
    yup, buy 'em for 2g
    1994 Galant GS 5spd
    right on. will be placing my order next week for the parts.
    Does anybody know the dimensions for the metal bushings? I'm a machinist and can make some out of scrap aluminum. Just need to know the main diameter, the stepped diameter, and the hole thru. Thanks.
    02-17-2011
    i live in sunny florida
    1,240
    If you don't have an answer later today i will pull mine apart to give you them
    Sent from my PC36100 using Tapatalk 2
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    Ok, thanks
    07-02-2011
    South Florida, by the beach
    1,076
    Is there any bearings that will fit in the 3g eclipse shifter cables? I took mine to a local Bike and Board shop but they had a tiny selection(I hate living in a small town) and all the bearings were too small
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    You could always measure the ID of the cable ends, measure the posts, and order some bearings online like mcmaster-carr or maybe msc direct.
    Quote Originally Posted by Black8GV6 View Post
    Here you go:
    http://speed-source.net/wordpress/?s=mitsubishi
    The shifter cable and base bushings you will want are for the Evo 8 5-speed. Simple as that. I waited until this year to buy these and I can't believe I didn't do it when originally doing the manual swap a few years ago. They are such a great upgrade.
