Thread: Performance Mass Air Flow Sensor
Showing results 1 to 5 of 5
    christiantuner
    Any know if their are any Performance Mass Air Flow Sensor's for a 90 DOHC 2.0 out their?
    MAFT and MAFT Pro
    Or upgrade to a stock 2g MAF
    Mr. O
    GM MAS blowthru
    07-20-2003
    Orlando, FL
    3,169
    -Upgrade to a 2g MAF (Had higher airflow reading)
    -MAFT or MAFT pro to which you will have to buy a GM 3" MAF. (Allows venting to the atomosphere)
    Mr. O
    Quote Originally Posted by 4-G-rim
    With that setup he & I said you will need a GM MAS Translator, wich will set you back $200. But that setup does allow you to vent to the atmosphere aswell as it flow much better, a hotwire MAF (which is what that is) is far more accurate than a karmen vortex maf (found on a DSM). You can also get a decent tune with it aswell.
    it's worth the money I say...
