Thread: 9G maintenace
Showing results 1 to 4 of 4
    05-31-2005
    4,735
    9G maintenace
    can someone tell me what i need to do for 30k maintenance. i lost mine.
    05-31-2005
    4,735
    oops found the online one.
    add if you want to be exact .
    EDIT: eh... it only says change oil/filter, air filter, and rotate the tires and some bunch of inspectins. I bet i saw more on the actual maintenance manual.
    <div class='quotetop'>QUOTE(9G)</div><div class='quotemain'>oops found the online one.
    EDIT: eh... it only says change oil/filter, air filter, and rotate the tires and some bunch of inspectins. I bet i saw more on the actual maintenance manual.</div>
    for severe usage (which ALL cars fall under), you need a trans fluid change, coolant change, oil change, air filter change, tire rotation, and a plethora of inspections.
    05-31-2005
    4,735
    ^^ hey, is cleaning the throtle body the same with regular cable once? my car is running really poorly(gas). its all motorized but can i still push it in or do i have to have someone stepping on the gas pedal to get it opened. Or am i really off. how should i do it?
