I got the Haynes manual....but no scanner....And my girl went out with my camera....What is exactly your need...and for witch model?
does anyone have a headlight wiring diagram?
04 GTS 9G
FoR Sale:
2004-2006 Fog Lights $50
shoot me a pm
Sly
I don't pop it open for strangers...my hood of course ;)
<div class='quotetop'>QUOTE(opinaca)</div><div class='quotemain'>I got the Haynes manual....but no scanner....And my girl went out with my camera....What is exactly your need...and for witch model?
</div>
Well, i'd like to know which wire is the low, high and ground on each headlight...
I read on another thread that they are not as you would expect.
-Pedro
<div class='quotetop'>QUOTE(Kalamidad)</div><div class='quotemain'>
I read on another thread that they are not as you would expect.</div>
On 1999 to 2002 and later models:
Left one:
the Low is the Org/Blu
And the High is the Yel/Red
the Ground is the Black wire.
Right one:
the Low is the Wht/Red
And the High is the Lt Grn/Red
On 1998 and earlier models:
Both sides identical:
the + is on both sides and the ground is switched on either sides.
the +is the Red/Blu wire...appears by the closing of the Headlight relay.
the Low is the Black to ground permanently
And the High is the Red switched to ground by the column switch Hi
Good Luck!
Sly
its an 2004 galant GTS and i need the entire wiring diagrams for the headlights high and low, parking, etc, and the fog lights
04 GTS 9G
FoR Sale:
shoot me a pm
Sorry...only got 1994 thru 2003 Galant...Good luck!
Sly
do u still need it? i have the whole dealer technical manual on cdrom around here somewhere and it has all the diagrams u asked about
That would be great. can you send it?
04 GTS 9G
FoR Sale:
shoot me a pm
careful what youre doing.. the whole lighting system is basically solid state, and runs through the front ECU. the DRLs are duty cycled at 80 percent lumencense.
what Im trying to say is that you could fry something pretty easily if you dont know what youre doing.
Originally Posted by LOST
That would be very nice of you ....for all of us to share....that's interesting knowledge material....
Sly
