Thread: Manual Transmission code
Showing results 1 to 7 of 7
    6a11v6
    Hey all, i'm tryiing to find out the code for the manual transmission for the 6a11 v6 SOHC. Its the same engine thats inmany of the 7th gen galants. I'm swapping the auto, but I cant seem to find the code for the 6a11 engine. Can anyone help?
    thanks
    ps. i tried searching, but was only finding info for the 4g64 and the 6a12
    6a11v6
    no one knows? :evil:
    i think mine is a FA22
    but i'll have to look again.
    6a11v6
    hey thanks for the reply..
    can you please confirm it for me, so far you're the only one that has another engine like mine, so i'm depending on ya
    pls man, can you confirm it for me?
    uhm, no. as far as i know, 4g63 does not equal v6!!
    6a11v6
    oh, didn't know he had the 4g63, i thought he was referring to the 6a11 as well
    so i guess i'm still looking then :evil:
    help
    6a11v6
    Ok folks, updating this thread as well. After much searching I eventually linked up with someone in Barbados who successfully did the swap. The code for the box is f5m41, basically the 4g15 and 4g93 boxes work, as they have identical bellhousings. I dont know if it applies to the US Spec engines, as these were JDM that were worked on. Heres a link:
    http://forums.trinituner.com/forums/viewto...&highlight=6a11
    regards
