check the tires. there is always one on the tires. that is where i have always seen them.
Hey guys was just wondering what the correct tire pressure is for my 2001 V6 galant with 16" rims is? There is no tire pressure label on the door jam of my car, which there is supposed to be..
Thanks
2001 Galant ES V6
2001 Mitsu Galant ES 4Cyl.
WRONG. the tire pressure on the tire is the max PSI. you don't want to be riding around on MAX PSI.Originally Posted by GAGalant01
but i looked on my label and its 32psi on the front and 29 psi in the rear
note that that is the pressure when cold.Originally Posted by pinoyesv6
meaning before the tires are warmed up.
not the pressure in the winter time.
i.e. if you just got off the expressway after driving 10 miles, and checked your pressure, it would be higher than normal.
Thanks pinoyesv6 that's exactly the answer i was looking for !!
2001 Galant ES V6
