first of all, try a search in the 8g forum, there could be some insight there. well im for sure there is but there should be dozens of threads there
<div class='quotetop'>QUOTE(brandon)</div><div class='quotemain'>1. What kind of paint did you use for your interior (I'm talking about the vents, dash pod, door trays, center console, trim around shifter, etc).
</div>
on the plastic pieces you can use any kinda paint you desire. just make sure that the paint you use won't melt plastic or something like that
<div class='quotetop'>QUOTE(brandon)</div><div class='quotemain'>2. How many coats did you use? Did you clear coat it after? Â*
</div>
2 or 3 coats will be good. if you didn't use a primer maybe a layer more. uhm just paint it til u get a nice smooth layer, do a light sanding between layers. A clear coat is optional but help to protect your finish
<div class='quotetop'>QUOTE(brandon)</div><div class='quotemain'>3. Will it crack if I do it now? Temperatures here are in the 30s - 40s.
</div>
Im guessing your taking the temperature in Fahrenheit so my suggestion is to wait til it gets warmer or paint the pieces in a warmer area like a heated garage or a well ventilated basement. uhm chances are you are gonna be spraying the paint on and its a lil bit more difficult to sray when its near freezing temperatures. also its gonna take forever to cure
