Thread: 18" x 8s w/38 offset
Showing results 1 to 7 of 7
    qbcrusher
    Hope I didn't screw up I just bought 18x8 w/38 offset 225 40r also installing Eibach pro kit wil I have clearance probs? any input would be great.
    i believe you are going to rub. My falkens are 18x8 w/ a 38 offset i believe and i rub constantly in the rear. But Im also dropped on teins w/ kyb-agx. The eibach wont drop ur car as much as mine but u will rub. I guess I can suggest a lil negative camber and rolling ur fenders. Others might have better advice then this though....
    qbcrusher
    Is the clearance the same on my 03 as your 99? i will be pissed if these rub, the place i am getting them from GUARANTEED they wouldn't rub. I had a feeling the +38 offset might be to much. Thanx for the reply, anyone else have input.
    the 99-04 pretty much have the same suspension and body, minus the bumpers. so clearance will be the same.
    you know, with such a low offset, you're cutting things close. what i recommend you do is go ahead and lower the car and see what happens.
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>the 99-04 pretty much have the same suspension and body, minus the bumpers. so clearance will be the same. Â*
    you know, with such a low offset, you're cutting things close. what i recommend you do is go ahead and lower the car and see what happens.</div>
    I think what you meant to say is 99-03.
    Worst case: You'll roll your rear fenders... You likely wont rub in the front. That offset will make your car look very nice and aggressive too!
    <img>
    ugh, this happened to me. i bought a set of wheels off ebay. i love the wheels but the guy promised 18x7.5 et43 and they came and they were 18x8 and et 38 :evil: they do stick out a bit. and my tires look a little tiny bit stretched. my car isnt dropped, but when i do drop it, I'm rolling my rear fenders. without that it will definately rub. you wont have any problem with the front though.
