Originally Posted by
B19WHEELS
I just installed my safc 1 in my car but for some reason my rpms are reading wrong. Ive unhooked and rehooked up this thing several times and still the same thing. Can anyone tell me what can be wrong? Oh yea is my safc suppose to monitor a/f% also?
don't use your safc2 to monitor o2 trims, it will alter the signal to the ecu and your car won't run properly.
as far as rpm's go,
what do you mean its not reading properly. do you mean its off by a couple hundred, or the numbers do not corelate with your tach at all?
if they do not correlate, then you have tapped the wrong wire for your rpm signal.
