Thread: Down, but not out
Page 3 of 3 FirstFirst 123
Showing results 41 to 44 of 44
  1. #41
    thats all weight i pulled off the rotating assembly.
    i used the oem spacer from a 1.6l to get rid of the balance shaft sprocket that goes under the crank sprocket.
    Left BS weighed 3lbs, 7.4oz and the right was 2lbs, 6oz., the pulley was 6oz For a total of 6lbs, 8oz
    not a bad weight savings. i think my chromoly flywheel was only 7lbs lighter than stock.
    with the aluminum crank pulley, b/s delete, adn light flywheel i think i'm weighing in at close to 18 or 19 lbs lighter rotating assembly than stock. thats not factoring in the no a/c.
    car s driving smooth as ever.
    :idea: i'll give my next update in about a week and reveal my next major mods. which are already in progress.
  2. #42
    How did you remove the front BS? Drop teh crossmember? Mine wouldnt come out witht he crossmember still there.
  3. #43
    12-17-2002
    Sherman Oaks, California
    4,304
    very very very cool, can't wait to do it on your old motor....oh wait i already removed them...
    http://socallifestyle.com/
    1994 Galant GS 5spd
  4. #44
    <div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>How did you remove the front BS? Â*Drop teh crossmember? Â*Mine wouldnt come out witht he crossmember still there.</div>
    dropped the crossmember, not completely though, i lossened the rear bolts and took out the front.
    with a little english it came out.
    its a bitch getting up in there to block off the front passenger side bearing
