Get your volt meter ane double check it is running on 12volts. Then when you know the voltage go and get yourself a T-1 size LED. they are pretty small.
edit. btw you can easily use any voltage LED under 12v if thats what it runs. Just need to get out your good ol' resistance calculator and figure out what OHM resistor you need.
