Thread: Billet Resivior Caps for the 8G & 9G Galant: Brake Caps
Showing results 1 to 8 of 8
    Tearstone
    This weeks marks the first week of production for the billet products offered by Tearstone Performance.
    Made from billet 6061-T6 aircraft grade aluminum crafted specifically for the brake cap of the 3G/4G Eclipse and 8G/9G Galant here now.
    The problem I and other owners have been faced with over the years when going to shows is that spray paint simply does not do the trick when dressing up the plastic in your engine bay. Regardless of scuffing, the paint still peels and looks nasty (pictured below). I have painted mine 3 times and the result is still ugly. Thus, the billet dress up items are born.
    I sell these on http://tearstone.com for $65 shipped.
    Call 407-580-1667 or [email protected]
    Below in the pictures depict a stock brake cap and a Tearstone Billet brake cap
    Russ, you'll be getting lots of business from me soon, and not just little accessories like this
    <img>
    Tearstone
    <div class='quotetop'>QUOTE(ChikagoGTZ)</div><div class='quotemain'>Russ, you'll be getting lots of business from me soon, and not just little accessories like this </div>
    Look forward to seeing you bud
    this goes over the factory brake cap right?
    Tearstone
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>this goes over the factory brake cap right?</div>
    yessir, so it retains the use of the stock diaphram. When I do the power steering cap I have to do that as well since it is too complex to make these replicas of the stock caps and the cost would sky rocket on these then
    Those look real nice!
    Lo§'s 99 GTZ
    do you know how much higher the cap is with the cover? im thinking about it but with the clearance i have with my strut bar, im afraid it might not fit.
    Tearstone
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>do you know how much higher the cap is with the cover? im thinking about it but with the clearance i have with my strut bar, im afraid it might not fit.</div>
    The cover ads like 1/16th of an inch of thickness (if that) to the existing brake cap. Imagine taking your stock brake cap and wrapping it in aluminum foil. This is sort of the same thing except with billet high grade aluminum.
