they make a halogen 1156 bulb that you can use. it puts out 50 watts.
my main concern with that is heat. with you go to reverse, you're only in reverse for a like a minute or less. but if you're using it as a rear fog, its on for a while and the heat can build up. not sure how the factory tail would react to the heat.
i know there are some members here with jdm/euro tails on their 7g. i know some of them have rear fogs, you might want to see how those are setup
