glad to hear you got it running Noel, I knew it had to be that resistor pack. I read thru countless wiring diagrams and thats all i could come up with, given the symptoms you gave me. If your dumping oil that bad, check out the oil pressure sensor on the back of the block to make sure its there, also check to make sure its not coming from the timing cover, if it is, it sounds like the plug that blocks the balance shaft is loose or fell out. Also, are you running an oil cooler? If not, you should be, they are cheap insurance to prevent burning up the oil. hit me up if you need anything.
