Thread: Spark Plugs
Showing results 1 to 5 of 5
    smonijhay
    Spark Plugs
    What are some good plugs for Galants? I wanted to try Bosch Platinum 4's. What do yall use? :?:
    Experienced TGC Member
    07-31-2002
    San Antonio, Tex-Mex
    1,413
    Actually I use those in mine. They are kewl
    Anything platinum is good cause it will last a lot longer than copper, other than that... there's no real benefits to expensive plugs.
    Just make sure they are gapped correctly :thumbsup:
    [b]<span style='color:blue'>Wes</span>
    The true path to enlightenment is Here
    <-Check it out Maz
    My 7g
    [b]<span style='color:darkred'>ClubTGC Shidoshi-Kai Fellowship</span>
    Oli97GalantES
    Got the same ones for my ride. I liked them because I didn't have to worry about the gapping(already gapped for you). 8)
    07-31-2002
    Bronx NYC (reppin)
    3,489
    Right now i'm using NGK's they got me going smooth.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Initial -G-host
    I am using NGK Iridium plugs in my motor right now. Make sure your gap is right but if you have more mods done to the motor the closer the spark gap has to be. Good Luck
