Thread: installing dsm injectors and building the head
Showing results 1 to 3 of 3
    does anyone have the wiring dirgrams for dsm injectors, and does anyone know where i can find lifters and valves for the stock shoc?
    i hope this helps
    this is the wiring i got here a while back for the injector resistor pack that u probably need.
    hope that helps.
    07-20-2003
    Orlando, FL
    3,169
    Re: installing dsm injectors and building the head
    <div class='quotetop'>QUOTE(Boostedgalant56)</div><div class='quotemain'>does anyone know where i can find lifters and valves for the stock shoc?</div>
    Are you planning to upgrade? If so...all you really need is to stay stock using OEM mitsu lifters. For the valve and valve springs if you are looking for a upgrade route, the only company that makes them is RPW.
