Exhaust flange bolt spacing
Does anyone know what the [main cat] flange bolt spacing is?
Or for that matter, is it possible to use a stock 2G main cat (dimension wise, they seem to be the same)?
Thanks.
edit: So far from what i can tell, it is a bit larger than 3".
If you still need it tonight, I've got my old cat+piping in my garage and will measure it for ya.
<div class='quotetop'>QUOTE(wanderingpinoy)</div><div class='quotemain'>If you still need it tonight, I've got my old cat+piping in my garage and will measure it for ya.</div>
That would be great dude. Need the specs in order to order the proper flange for my dp.
