There are two types of Eclipse manifold: the GT and GTS. We have the GT manifold in our cars (squished). The GTS has more equal length runners with a butterfly flap to switch to shorter runners.
There is also the Diamante manifold, which is supposed to be the best flowing of the three.
The GTS and Diamante will bolt up with minor modification and wire extensions. Note that you may need to relocate the battery as the GTS and Diamante manifolds push the throttle body into the battery tray area.
RPW also has an upgrade manifold, and from what I recall is pretty close to the Diamante manifold.
