Thread: "Thunking" from rear suspension
Showing results 1 to 11 of 11
    Everytime I go over rough road or hit a bump, there is a "thunking" sound coming from the rear of the car. At first I thought it was the spare bouncing around but then I completely emptied the trunk and the same thing kept happening.
    Took the rear wheels off and did a visual inspection and didn't note anything wrong. I cannot tell which side the sound is coming from either.
    Any ideas? Bad struts / strut tower?
    Thanks!
    --Don
    2002 Titanium Grey Galant GTZ
    ==> Totally stock... so far
    07-31-2002
    Bronx NYC (reppin)
    3,489
    Could be your struts or strut mounts
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    I suspected that might be the case. Any idea how much something like costs to fix?
    <div class='quotetop'>QUOTE(clevelandGTZ)</div><div class='quotemain'>I suspected that might be the case. Â*Any idea how much something like costs to fix?</div>
    Rear struts, strut mounts, labor and alignment $400-500 depending on the shop. You would want to do the front struts with that so expect $700-800. At a shop at least, obviously less if you are a do-it-yourselfer.
    Experienced TGC Member milo111000's Avatar
    08-06-2005
    Long beach/ guam
    1,585
    just take it apart and have a look. could be only ur bushings. but make sure. struts could be pricy.
    02-28-2005
    Metropolis
    3,540
    Devgrp had that problem earlier. Here's a link
    https://www.thegalantcenter.org/viewt...uspension+noise
    Yikes! Pretty expensive stuff. I think I'll do some more investigation.
    Hopefully the weather will improve. Not looking forward to pulling things apart when it's 30 degrees. I'll give an update as to what I find out.
    Thanks!
    02-28-2005
    Metropolis
    3,540
    <div class='quotetop'>QUOTE(clevelandGTZ)</div><div class='quotemain'>Yikes! Â*Pretty expensive stuff. </div>
    Modding a car is expensive.
    <div class='quotetop'>QUOTE(SkylineG1)</div><div class='quotemain'><div class='quotetop'>QUOTE(clevelandGTZ)</div><div class='quotemain'>Yikes! Â*Pretty expensive stuff. </div>
    Modding a car is expensive.</div>
    properly maintaining the car is cheap.
    02-28-2005
    Metropolis
    3,540
    <div class='quotetop'>QUOTE(RedGalant2k1)</div><div class='quotemain'><div class='quotetop'>QUOTE(SkylineG1)</div><div class='quotemain'><div class='quotetop'>QUOTE(clevelandGTZ)</div><div class='quotemain'>Yikes! Â*Pretty expensive stuff. </div>
    properly maintaining the car is cheap.</div>
    True.
    Ha! Not in Cleveland it isn't...
    The cold is hell on the engine and it's a constant battle to keep things from rotting from all the road salt.
    Then there's the crappy roads. More holes than surface. I'll bet that's what caused whatever the "thunking" is. Last year I bent and cracked a rim. Snow filled crater -- invisible but nearly knocked my fillings out when I hit it. Ouch.
    Beyond that though, the car gets all the regular maintenance which is pretty cheap.
