They are on Ebay all the time. You have to look for indiglow, not indiglo. Search for Indiglow emblem and you'll see a shitload appear. I'm going to order a Nissan one for my other car to cover the hole where someone busted into my trunk. It would fit perfect too.
Click Here for the Ebay search for Indiglow emblem.
That poor seller, some dumb ass gave him a negative and said, "I do not wish to purchase item. Sorry, I have changed my mind." Sobe was this you? j/k The seller's response: "WTF, U Changed UR mind and NOT PAYING, & Give me - What For?" Then the seller gives the dumbass this negative feedback: "#1 AXXHOLE, WonAuction, NonPay, Giving U - Bcuz He Doesn't Want 2 Purchase it" Drama.
I've search through the internet looking for the brand Light Of EL Logo, but I couldn't find anything. (looking on packages..) Yep. Made in Taiwan. Maybe Jaspen can get us these for cheap. I'm going to order another one because the clear rubber part is sort of jacked on one of the corners. Looked like someone from the factory (as it was sealed) was trying to pry that thing off. It's sort of chewed looking. Very small though. Oh yeah, that's not the only reason as to why I would get another one, it's because I anticipate someone stealing it off the back, especially if I went to a car show. That shit happens all the time. I didn't secure it down with the supplied nuts and bolts. I just secured it with the sticky tape that was on the back of the emblem. Good enough for now. I didn't want to drill 2 more holes, you know, just in case this thing looked dumb or I got tired of it. But that was how I was thinking before I installed it.
If they did steal it, it would be useless without the mini ballast. That part is not inside the emblem itself but separate, like the Reverse El Gauge ballast, only smaller. Less than an inch square. I have these connected to the license plate wire. I used a soldering iron to melt away the plastic wire cover and then soldered the El wire into the license plate light's wire.
I also blue a fuse when testing this. When I had the wires just twisted together, I didn't see that they were touching and when I went to turn on the lights, the whole driver's side was out. I had to replace the 10amp fuse in the fuse box inside the hood compartment.
