I'll field this one guys. SEARCH! There have been threads on this before. But since your new I'll help you out. It is not as simple as swapping out our 4 for the 6a12. There is a reason those are on there for so cheap...no one will buy them! If you have a lot of money to burn that is the swap to do. You would have to re-inforce the front end of the car to handle the extra weight of the engine. If you wanted the all wheel drive, you would have to get a ne gas tank or modify the stock one because the rear differential has nowhere to go on the usdm car. Lastly (as far as I'm concerned) where are you going to get parts for the engine when something goes wrong!? This project would get very expensive and labor intensive. Just an FYI...I'm sure the others might have some more input, but thats my 2 cents
