Manybrews can probably confirm this off the top of his head, but You likely still have a fuse out. Check all of them, including the ones under the hood. Did you install aftermarket gauges or are these the stock ones that failed? I can tell you that if your gauge cluster blew out, you're looking at about $400 to replace the whole unit unless you can find a used one.
Chip
