Thread: Addco Rear Sway Bar Woes
Page 2 of 2 FirstFirst 12
Showing results 21 to 28 of 28
    02-07-2007
    ORLANDO
    1,599
    Did you buy it specific for the Galant, or pick up an Eclipse ADDCO bar?
    galant bar
    What I see is that your sway ends are way too in, I mean they go over the control arm and a little over.I'd say that youll need to modify it in order to get a good clearance. A 1/2 inch plank with holes in it between the rear cross member and the bushings will set the sway bar off to the back which will bring the ends to normal......or find longer end links
    sure ....it brought washers for that but if I do that it'll sit on the exhaust pipe like in that last picture so everytime i start it hits it
    i found stewi saying this
    The lower control arms on the 02-03 galant do not interchange with the lower control arms on the 99-01 galant. The 99-01 galant the rear of the control arm mounting point is a U shaped clamp that goes over the bushing, on the 02-03 models the same mount is a solid round bracket with a different bushing. I tried mounting it in my 99 and no dice.
    so beisdes the mounting point, maybe there's more a difference that may be causing the problem.
    11-13-2007
    -OKC-
    3,970
    When I first bought my Addco sway bar, it did the same thing. I contacted John at Addco and they sent me a free replacement that fixed the issues and I go to keep the old one.
    who wants to get rid of one of these
    11-13-2007
    -OKC-
    3,970
    Just buy one.
    02-07-2007
    ORLANDO
    1,599
    Thats funny,thats who i've spoken to about this issue....was it on your 02?
    11-13-2007
    -OKC-
    3,970
    Yes he is the owner and I supplied him with proof of the issue. There was no questions asked. Nice co and guy to deal with. I still have the first one I bought but shaved it down and it's ok now.
    Quote Originally Posted by shiznit013 View Post
    [And here is a shot of the bushing. That jizzy looking substance is dielectric grease. I used it for lack of finding anything better.
    http://cgi.ebay.com/ebaymotors/ENERG...2em118Q2el1247
