For your first problem about getting into gear did you check your shift fork position? It should be in the middle. It seems like you didn't space it and your fork isn't fully releasing the clutch. Get that fixed asap so you don't end up burning your new clutch. You can also adjust the pedal by backing out the clutch sensor alittle to give your pedal more travel.
For the second problem out of those 4 lines 2 have to be used to plug in your reverse light switch. I forgot which two though. You have to get small speaker female terminals and plug them into the reverse light switch.
Almost forgot and for the speedo make sure it is in properly w/ the 10mm bolt and the connection is good. It should have a retaining clip to keep it from backing out.
