Thread: These fit us?
Showing results 1 to 16 of 16
    These fit us?
    Anyone know if these fit us?
    17" Giovanna G-Racing Rims and Tires 4x100 Univ. 4 lug
    the lug pattern is 4x100 and 4x114.3
    Why I got half a mind to...ahhh...never mind I just got half a mind.
    Re: These fit us?
    the 4x114 will fit
    but make sure the offset is as close to stock as possible
    galant_got_speed
    i still dont understand rims and tires...i want rims though. i just dont want 17's cuz of the weight..id rather stick with 15's and do a big drop...neone else done that? i like the way 15's look...
    [quote="galant_got_speed"]i still dont understand rims and tires
    Makes two of us.
    Re: These fit us?
    <div class='quotetop'>QUOTE(gravy)</div><div class='quotemain'>the 4x114 will fit Â*
    but make sure the offset is as close to stock as possible</div>
    Thanks, how do I find out the offset?
    I believe its +45.Above 40 u should be ok with
    factory offset is +46mm. but pay attention to the width of the wheel too. too wide of a wheel and you'll still rub
    <div class='quotetop'>QUOTE(galant_got_speed)</div><div class='quotemain'>i still dont understand rims and tires...i want rims though. i just dont want 17's cuz of the weight..id rather stick with 15's and do a big drop...neone else done that? i like the way 15's look...</div>
    8)
    Signature wanted call: 1800-Darkkend
    <a>Take Better Photoshots Tips from the Pro's</a>
    Quote Originally Posted by gravy
    K thanks again , so how wide should the eims be so that they're OK fo us?
    07-20-2003
    Orlando, FL
    3,169
    Quote Originally Posted by jiul
    I wouldn't go wider that 8 inch wide wheel..and if you do go 8 inch wide try to stick with a +40-+42 offset wheel to prevent rubbing.
    Quote Originally Posted by galant_got_speed
    my konig prophet 18's and tires weigh within .5lbs of my stock 94 GS/LS wheels and tires.
    so i didn't really add any weight.
    however, i did pass up the oppurtunity to lose some though the upgrade.
    15's look nice, especially if you put some 205/55/15's on there.
    but i would stick with 16's at least so you can run a decent sidewall.
    those tall sidewalls just kill the handling.
    Kansas City, MO
    1,244
    Quote Originally Posted by Darkkend
    8)
    I'd hate the be the one to tell you this, but i think you missed the parking spot by a little. You might be sticking out in the front.
    8)
    what is that car sitting on suspention wise? like what kind of springs b.c that is the exact drop i want i my car.. its nice and low
    Quote Originally Posted by SuperGALANT
    8)
    Thats Redlant97 car im in the process of buying it, he has eibach prokit with kyb gr2 and the stock 15" in that picture now it has 17"s
    Go atleast 16...better handling with suspension upgrades
    No man is your friend, No man is your enemy, Every man is your Teacher
    well i had 17s w/ cheap tires and they didnt handle as good as the rims and tires that dohcstunr sold me.. i got his factorys that are gunmetal w/ traction t/a tires. man these handle sooo good
