bs A motor should be able to run alday everyday as long as oil life and coolants are ok..
I heard once that once you start your car it is nice to let it sit for a few minutes so the engine warms up, and the oil gets going, etc.; but that if you left it idle like that for 30 mins or more it would damage the engine....
Myth or Wisdom?
Retardation? Only thing your not getting that you get when you drive is airflow. But once your motor warms up and gets to 200-210 degrees, the fans kick on and cool it down a few 20 degrees. Like ipaintu said, as long as the motor has gas, oil, and coolant, you wont damage anything while idling.Originally Posted by galantebeige
I have let my car idle for 2+ hours. Haha long story...anyway it'll be fine.
Retardation!!
I tought it sounded weird. I could not understand why would it get damaged.
with the gas prices of today, i don't know why you would let your car just idle there for a very long period of time.
<div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>with the gas prices of today, i don't know why you would let your car just idle there for a very long period of time.</div>
its the new trend
What reasons would you leave your car idle for prolong periods of time anyways? Unless you locked your keys in the car while they are still in the ignition in still which case wouldn't damage the motor anyways.
prolonged idling is not good for the plugs cause they don't reach their optimal(self cleaning) operating temperature.
you can also gum things up pretty bad.
but nothing a few wide open throttle pulls won't fix.
its bad for your plugs.
and the environment
and your wallet
hmm I can think of one reason which involves doing something in the backseat at either very warm or cold outside temperatures
And BINGO was his name-o!Originally Posted by Gladiator
over heating is the problem.
There is only so much your Fan can do. The heat will still trap under your hood. A fan can only blow so much air out of there.
Compare to you driving on a highway, the wind rushes in are much cooling than your fan.
Honestly, the biggest problem wont be the engine cooling but your transmission. I know alot of police cars have upgraded tranmission coolers with electronic fans due to guys sitting in them doing traffic and other things (not sleeping). I had a Ford Explorer at my last job and the transmission wasn't updated, we went through 3 trannys in 2 years due to overheating since my crew spent at least 6 hours a day on traffic enforcement.
<img>
Thats if the car is in gear right?Originally Posted by ChikagoGTZ
No...as far as I know the tranny will still warm up when in park. At least that's what we were told ??Originally Posted by Gladiator
<img>
you also got to remeber that when u go on traffic enforcement you sit there. then you go out and chase someone and that heats up the oil then u go back to sitting so its harder to cool down that oilOriginally Posted by ChikagoGTZ
That's why you install one of these, most police interceptors have them:Originally Posted by pinoyesv6
<img>
If that is the case then 2 hours my ass.Originally Posted by Gladiator
lol.
Oooh I like that cooler, I need a new oneOriginally Posted by ChikagoGTZ
[Edit]
Ouch $209..
thanks guys for the info.
it seems then, that being idle is not the best thing. I'll keep that in mind.
