im at 15psi now on the 18g i still have the auto tranny with a pretty big cooler installed 17,500gw something lol... fluid looks good and the car shifts fine.
with the 18g i get full boost by 2800rpms now consider that the turbo and manifold are ported, it still uses the same turbine wheel as the 14b and 16g just with a bigger compressor wheel.
using the emanage makes a huge difference form using the safc2, having control over timing makes tuning alot safer.
in the next couple of weeks the low compression headgasket im having made will be done along with the shot peened rods and cryotreated pistons i wanna see what i can do with stock parts before i finish off the other motor im building
