you can't. because the elctronic boost controller simply modifies the boost signal to the wastegate by bleeding off boost.Originally Posted by Robotnik123
you turbos still have a base boost setting that is in the spring of the stock wastegate actuators. so there is no way to lower the boost beyond that point.
the onl way you could do it woudl be to bend the wastegate acuator arms to make them slightly longer. this way the wastegate flappers don't seat all the way and it will cause a dramatic decrease in spoolup.
