You need the code to put in the radio, but about the keyless entry problem I don't know.
I just bought an 03 Galant and today i tried installing a radio, the first time i plugged the radio in it worked fine and then i disconected it and i plugged it back in again and it didnt work. Now the keyless entry on the car doesnt work and the stock radio doesnt work either. I tried opening the car with the keys and it doesnt open i dont know why. If u guys had similar problems please let me now or give me some advice. Thank You
KH
u blew a fuuuuuse
under the hood, surrounded by yellow housing, fude 2 i think, page 7-24 thru 7-27 on the manual, should be the radio fuse
is that one inside the car or in the hood?
is there any way that i could open the car with the key?
the key should absolutely work.Originally Posted by galant186
You blew a fuse. The one you blew is located in that ugly yellow box in your fuse box.
I blew it last week. One fuse controls your radio, the other one controlls the dome lights, trunk light, and keyless entry.
The ho0o0o0dOriginally Posted by galant186
and yea ur key should work, put it in the door and turn left, u should be golden
hey thanks man, im gonna get a lock smith tomorrow and fix it. I was scrared because i thought it was something more serious. Can u buy that fuse in Auto Zone or Strauss?
Yes. Btw, you dont need a locksmith. Just put a fuse in, As already mentioned the keyless entry should work 8)
..bro, fuse.Originally Posted by galant186
Donovan J.
Need something from england..or other eastern nations holla...
I dont mind looking.
Car: Toyota Soarer GT-T Jspec "Limited"
Galant: at home chillaxen :(
but theres no way to get inside the car to open the hood because the key does not open the door.
use key to open trunk , from trunk to rear door..
if u cannot open ur trunk like that..
look under your "metal galant thingy" on the trunk where its all chromed out in "Galant" and two screws can undo there, undo the screws and take the peace off from there you can "trip the wire" to your own trunk...
oh by the way , dont let anyoe know I told you how to break into a galant
Donovan J.
!!!!!!!!!Originally Posted by Donovan
:shock:Originally Posted by Donovan
..what
ha
Donovan J.
My galant 03 doesnt have any place to put a key on the truck, this morning i had to call the locksmith and as soon as he opened the car, i opened the hood i took the fuses that u guys told me to take off and i replaced them and after that everything worked fine so thanks guys.
KH
But i still had to spend $110 on the locksmith which totally sucked.
i still dont understand how ur key didnt work in ur door, mystery to me
Ecactly, even the valet key will open the door. Just doesnt open the trunk or glove. but for us 02-03 guys, thats not much of an option anywatys
