Thread: Where to buy lower arm bushing?
Showing results 1 to 5 of 5
    After reading the bulletin about the wheel shake, I'm assuming replacing them is what I need to do to fix my 55mph+ steering wheel shake.
    First of all, has anyone here done this? Does this infact fix the bad steering wheel wobble problem when going over 55mph?
    I have plenty of brake wobble too, and plan on addressing that separately, but first I want to be able to drive on the freeway without feeling like my car's going to fly apart.
    Secondly, if this is what I need to replace: what's the best place to find this part? Direct from the factory? What should I expect to spend on it?
    Thanks in advance.
    Ok, looks like I found them here: http://www.trademotion.com/partlocator/ind...M&siteid=214144
    Is that all I need? Just buy two of them?
    If my bushings need replacing, does that mean my lower control arm's bad too, or should I just replace the bushings and see from there?
    i am surprised no one's answered you yet. It may be easier to get the whole arm unless you are able to torch out the old and press in the new bushing.
    i actually have a replacement set from Energy Suspension that i was going to install but never did. i was going to post them up for sale.
    they're still brand new sealed in the original packaging.
    make me an offer i'll get you pics by the afternoon.
    Cali: Sig 3/28/2011
    DoverWhite
    IMO, if you're getting shaking, i don't think it would be the bushing. It would most likely be due to wheel balancing. Have you tried getting all your wheels balanced? It fixes wheel shaking 95% of the time.
    I've had lower arm bushings go out on my old MX6 I used to have. When it goes out, what I experienced was the car would randomly 'shift' from side to side while driving. Not shaking.. more like skiing back and forth. Really scary.
