Thread: Just how much does a 6g weigh GVW?
Showing results 1 to 5 of 5
    If anyone knows off hand or can take a look in there 6g please let me know..my curiosity is killing me.
    talontd
    2wd:
    SOHC - 1700Kg / 3,747lbs
    DOHC - 1780Kg / 3923lbs
    4wd:
    DOHC - 1900Kg / 4,188lbs :shock:
    :shock: is an understatement but I guess all that drivetrain would add the extra weight but DAMN that weighs more then my 8g lol I guess I"ll pick up that 6g gsx I found
    talontd
    Well those are the numbers in the manual but everywhere else that i check shows that the car is lighter than that......
    So I dunno... so the GSX shouldn't weight any more than the VR-4 where u looking at about 3500lbs or so....
    True, but thanks alot for the info. That weight is fine with me especially with the power I can get on the ground with AWD
